Question about Sony VAIO VGN-N130G/W Notebook
Touch Pad and mouse buttons
After accidently re arranging my icons on the task bar (windows 7) the touch pad and both mouse buttons stopped working. I pressed the power button (presumably putting it on stand bye) then pressed it again. This time the touch pad worked bt only the right mouse button worked, the left still didnt. I restarted the laptop and the touch pad and mouse buttons didnt worked AGAIN. I put it on standbye and the same happened, the touch pad started working and only the right mouse button. Now only the touchpad and right mouse button work. Help please? ;p
Posted by jasoncontrol on
aleshaseliya
    New Friend:
    Problem Solver:
  • 19 Answers
Try it with toggle keys it may be work
Posted on May 03, 2017
4 Related Answers
Anonymous
  • 120 Answers
SOURCE: touch pad not woring
Oh, I think a driver issue did it. Did you download a new driver? Maybe the maker had some bugs. Use Windows System Restore to reset the settings to a couple of days back, when it was working. It won't harm any of your personal files, though it seems scary and is time consuming. Or, you can try to do a Driver Roll-Back. Go to Device Manager (right-click My Computer -> Properties -> Hardware Tab -> Device Manager Button) and look for your mouse. Click Roll-Back Driver under some tab. It may work.
Or, just report to the company about the driver and search for the previous drivers.
For any other problems with the computer, like if there is no sound, visit my YouTube Channel (http://www.youtube.com/user/Antrikshy). Sorry, there was a problem in inserting a hyperlink.
Hope this helps, and please rate this answer the better you like it.
Posted on Dec 10, 2008
Don Forgash
  • 41 Answers
SOURCE: SONY VGN-FZ240E TOUCH PAD NOT WORKING
go to control panel , system , hardware, device manager & uninstall it then reboot
it will re install it's self.
don001996
Posted on Jul 19, 2009
mcdevito75
Michael C. De Vito
  • 1970 Answers
SOURCE: Left mouse button of Sony VGN-NR38M (nt touch pad)
mcdevito75 here, Bring laptop to Staples, Best buy for testing, sounds like that key could be hanging up. maybe some sort of oil needed.
Posted on Jun 26, 2010
albert700
Chip Davis
  • 4 Answers
SOURCE: The left button of Mousepad(one on laptop, but not
I had the same problem . The micro switch needs to be replaced . All push button micro switches have a certain amount of "clicks" before they loose ability to make a good contact . Your left click switch has exceeded its life and can no longer make a clean contact without more pressure . Eventually the spring in the switch will fail thus stick permanantly.You will have to take it to an authorized Sony Service center or maybe an office machine service department might have the replacment . I fixed my own with an old mouse microswitch .
Posted on Sep 30, 2011
Hcl me laptop, touchpad too sensitive, how to control?
There is an adjustment for this sensitivity go to control panel and look up the mouse if there is not icon on the tray to do any options. What your looking for in short is options in the option tick sensitivity there you can adjust it for your comfort. Locate this and your on your way. If you cannot find any touch pad information go to your manufactures web site and download the driver or software for your touch pad. It should drop to the task bar as an icon below. Or if you have the show all icons turned off turn it on it may be in there. The best way to do that is right click in the tray where the icons are and select show all icons or if you see the mouse pad icon there open it and tick options.
That is what I would do Win 7 may have loaded it but the actual configuration files may not have been downloaded, you may also wish to check out the Windows Updates and tick on all the updates you have missed you may find the software there for the mouse pad updates.
That is all I can offer maybe someone else has a better answer here. John
Apr 12, 2012 | Lenovo IdeaPad Computers & Internet
The mouse move round with the touch pad but fail to click on to items again
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
in windows 7 click start control panel harware and sound mouse you will see the same tabs and options as with xp
hope this helps
Feb 21, 2012 | Toshiba Satellite Computers & Internet
Have an Acer aspire 7720-6712 laptop; pad doesn't work. downloaded drivers, still doesn't work. task bar has icon saying pad is ok
if your pad is not working even after the driver is installed then it might me a physical problem. Better get it checked with some hardware technician.
if the service cost seems high or costly better by a optical mouse and use it. it would be comfortable rather using a touch pad.
Regards
Rudra.
Oct 11, 2010 | Acer Aspire 7720 Notebook
When get to my home screen my cursor wont move when I move my finger on the mouse pad.
I'm assuming that you are using a laptop. If so, then look around for a button that locks out your touch pad from being recognized. Some laptops have the Touch pad "On\Off" button just above the touch pad. Other laptops will require you to do a key-combination to turn the touch pad On or Off. To do this typically requires you to press the FN or Function key while pressing one of the keys between F1 - F12. There should be a symbol\icon of a different color on whichever key it is that will give you an idea of what that key's function is. Every laptop is setup and arrange slightly different.
Aug 17, 2010 | Computers & Internet
Acer aspire 5517 touch pad not working.
Also on this laptop you can hit Fn+F6 to enable or disable the touchpad as well there should be a touchpad disable button to the right of the power button that can be very easy to accidentally press.
Mar 15, 2010 | Acer Aspire 5315 Notebook
Can't disable touch pad
Windows hides rarely used icons. If your does, then the task bar shows a left pointing arrow < . Click it and look for the icone for touchpad.
If you cant find that icon,
In WINDOWS XP
1. Start
2. Contol Panel
3. Right click the Mouse icon.
4. Under the Touchpad ON/OFF thumbnail, put a check mark in the disable option.
5. Use the same procedure to enable touchpad
Aug 22, 2009 | Dell F3534 Touchpad
Touchpad scroll is not working in my laptop lenovo 3000G430
download synaptics pointer device off the net its free.
Aug 14, 2009 | Computers & Internet
Touch pad not working not sure if correct driver is instslled or a mechanical issue.
I'm assuming this is a laptop and not a desktop, since I've never seen a touch pad on a desktop....but unless you've had some work done to it in the past...i.e. new keyboard/hdd/memory where it could have been disconnected from the logic board, your touch pad has gone bad, and will need to be replaced...or you can pick up a much cheaper mouse and use with the unit.
Apr 29, 2009 | Computers & Internet
Dell inspiron1501 touch pad sensitivity problem
you are going to have to go into the control panel and to the mouse properties. in there you will be able to put the icon back in the taskbar. i dont know why it changed itself though. on my dell a couple times i had to reinstall the mouse drivers for some reason. i just went to dell.com and got them there. hope this helps
Apr 22, 2009 | Dell Inspiron 1501 Laptop
Keyboard
From the Dell D620 Users Manual:
You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
  1. Open the Control Panel and click Mouse.
  2. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad and track stick.
    • Click the Pointer tab to adjust touch pad and track stick settings.
  3. Click OK to save the settings and close the window.
The Mouse Properties utility is found like this:
Start Button>Control Panel>Printers and Other Hardware>Mouse
or in the Classic View
Start Button->Control Panel-> Mouse
Dec 31, 2008 | Dell Latitude D620 Notebook
Open Questions:
See all Sony VAIO VGN-N130G/W Notebook Questions
Sony VAIO VGN-N130G/W Notebook Logo
149 people viewed this question
Top Sony Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
