SOURCE: fly fusion
I just had this same problem, and the Fly Fusion website has this to offer (the website link is http://fly.custhelp.com/cgi-bin/fly.cfg/php/enduser/std_adp.php?p_faqid=1619&p_created=1201901554&p_sid=fj7lBboj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPSZwX3NvcnRfYnk9JnBfZ3JpZHNvcnQ9JnBfcm93X2NudD04NSw4NSZwX3Byb2RzPSZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTE*&p_li=&p_topview=1 or you can go to Fly Fusion supprot link and click on the FAQ section to access this information):
Question
Unable to install FLY World on Vista
Answer
If you are unable to install FLY World on the Vista operating system, please follow these instructions.
1. In windows explorer navigate to c:\windows\system32
2. Find the application named "cmd". Now right click on "cmd" and select "Run as Administrator"
3. In the following window, type or copy and paste
regsvr32 /u vbscript.dll
Now press enter. You may receive a pop-up regarding DllUnregisterServer that it succeeded or failed. In either case, click OK.
4. Next type or copy and paste
regsvr32 /u jscript.dll
Now press enter. You may receive the same pop-ups regarding the DllUnregisterServer message. Click OK once more.
5. We will next need to type or copy and paste
regsvr32 vbscript.dll
and press enter. You may once again receive the pop-up window. Simply click OK to continue.
6. Finally, type or copy and paste
regsvr32 jscript.dll
7. Try running the installer again.
SOURCE: fly pentop Q
no the on in the link is a fly pen 1.0 the one where you have a usb on the top is the fly pen 2.0
SOURCE: i tried installing the fly fusion but the CD wont
I would call Leapfrog. The number is listed below. Advise them that your cd will not load. What kind of computer system are you using the operating system you are using because there should be a place where you should be able to select the location of the cd and load the cd. If not go ahead and call Leapfrog they should be able to give you some kind of assistance.
General support: 1-800-701-LEAP (5327)
SOURCE: My FLY Fusion Pentop Computer won't turn on, but
Try leaving it hooked up to the computer for a while then after maybe a few hours try to turn it on again.
