it just has to charge. whn i turns d its charging. leave it for 15min andn take it out and turn it on. if it doesnt tn on contact an expertfrom the place u got it.
Question
Unable to install FLY World on Vista
Answer
If you are unable to install FLY World on the Vista operating system, please follow these instructions.
1. In windows explorer navigate to c:\windows\system32
2. Find the application named "cmd". Now right click on "cmd" and select "Run as Administrator"
3. In the following window, type or copy and paste
regsvr32 /u vbscript.dll
Now press enter. You may receive a pop-up regarding DllUnregisterServer that it succeeded or failed. In either case, click OK.
4. Next type or copy and paste
regsvr32 /u jscript.dll
Now press enter. You may receive the same pop-ups regarding the DllUnregisterServer message. Click OK once more.
5. We will next need to type or copy and paste
regsvr32 vbscript.dll
and press enter. You may once again receive the pop-up window. Simply click OK to continue.
6. Finally, type or copy and paste
regsvr32 jscript.dll
If you go to the LeapFrog Website and at the bottom select customer support you can then select the fly fusion. The guide you are looking for is entitled "Fly Fusion Parent Guide" I know it's not named the way it should as it is a general guide and not just about account administration.
http://www.leapfrog.com/etc/medialib/leapfrog/fly/ffls_37735.Par.40053.File.dat//Users/na/Desktop/Parent%20Guides/FFLS_37735_PG.pdf
OK ... after a lot of trial and error, I got mine to work. I think it may be a really low charge or something. I had to press the power button until it was completely dark ... no flashing faint green or any colors. Then when I plugged it in, I got a solid red and left it for awhile. Then when I pressed the power button I got yellow, red and green ... the computer recognized it and then got a solid yellow.
Before when I had it plugged in, I'd get a lot of red random flashing ... and it just didn't seem to charge at all ... even after a full day.
I think the issue was that it was in this "flashing state (red when connected, very faint green when disconnected)" It wasn't easy to get it to turn off completely. Most of the presses of the power button didn't change the state at all. But if I got it just right, I could see the faint green light go off. That's when I plugged it in and got a solid red light, and eventually a good charge.
Try pressing the on/off button to turn it off. I had a same problem. I depressed the on/off button for ~6 second or so and the device turned off. When I turned on again, the LeapReader no longer had a white light and was recognized by my computer.
Enter 1111 and it will say oops wrong password then enter 419 backspace and get rid of the 9 and then 27 worked like a charm took forever to find one that worked and this one worked for me once in change the 4 digit code to something ez
