My Router is out of warranty how do I troubleshoot it?
Hi, the BEFW11s4 sometimes is just a plug and play router. If your internet is working when your pc is connected to the modem, just do this steps.
1:Lets reset the BEFW11s4. with the power on, push the reset button at the back of the router for 30seconds, unplug the power of the BEFW11s4 for 10 seconds.
2:Disconnect the pc from your Comcast modem. Connect the ethernet cable from your modem to the INTERNET PORT of the BEFW11s4. Connect the pc to the BEFW11s4. NOTE; MAKE SURE THE PHYSICAL CONNECTION IS CORRECT.
3.Open INTERNET EXPLORER. ONLINE OR NOT?
A. IF ONLINE, clear the address field then type 192.168.1.1, if it ask you for a username and password, then we are ok. THE ROUTER IS ALREADY WORKING.
B. IF NOT ONLINE, TURN OFF PC, TURN OFF BEFW11S4, TURN OFF THE COMCAST MODEM. WAIT FOR 3 MINUTES
TURN ON MODEM, WAIT FOR 3 MINUTES, TURN ON BEFW11s4, WAIT FOR 3 MINUTES, TURN ON COMPUTER
IF STILL NOT ONLINE. Open internet explorer, type on the address field 192.168.1.1, username(nothing, as in blank), password(admin), click ok.
It will take you to the Linksys configuration page(Purple and white screen. On the screen you can see tabs
SETUP WIRELESS APPLICATIONS AND GAMING
MAC CLONE
CLICK THE MAC CLONE TAB, then click on Clone or Clone your pc mac, the save settings at the buttom. After this try the internet. If still offline, unplug the power of the BEFW11s4 for 10 seconds, try the internet again. It should be working now.
If still offline, do STEP 3B AGAIN. IT SHOULD BE WORKING ALREADY. IF THIS DOES NOT WORK, you really have to buy a new router.
I have solved this exact problem more than a thousand times. It always work if the router is still ok.
Good Luck
