20 Most Recent Linksys BEFW11S4 v4 broadband DSL router modem switch Questions & Answers
Turn over router and check in the bottom default access IP address and then type that IP address in to your browser. Then it shall ask you for ID and password. Enter `Admin` or `admin` as ID and `Password` or `password` as password. You will see a web based setup opened in front of you. Go to the Wireless Lan settings and then you will SSID so change the SSID and this would be your network`s name. Then go to subsection security and select WPA2-PSK or simple WPA-PSK then enter your desired network key. Once done with all these things the click apply and reboot if prompted.
Linksys BEFW11S4... | Answered on Nov 05, 2013
There are several factors that will affect or can cause problems in connecting your Roku to your Router.
If you're getting an error message on Roku like 014, 011, make sure to indicate it in your response. Normally, if you're getting 014 message, you can follow these steps:
. A simple power cycle resolves most of the issues. To perform a power cycle, please follow the instructions below:
1. Unplug the power cables from the modem, router and the Roku player.
2. Connect the power cable to the modem (after a minute). Once all the lights on the modem are lit, plug in
the power cable to the router and then to the Roku player.
3. Go to "Settings" and redo the complete Roku setup.
If the issue continues to occur, please try the channel 1 or 3. Should it persist, you may reset the Roku
player. Here is how:
On the back or bottom of the Roku unit, you should find a recessed little hole.
- Use a pin or paperclip to press and hold the button for 30 seconds (please ensure that the power light
blinks while you are holding it down).
The Roku device will reset to default and be ready for setup again.
If the problem continues, please reflash the software via the secret screen:
1. Press the "Home" button for 5 times.
2. Press the "Forward" button for 3 times.
3. Press the "Rewind" button twice.
4. Choose Update Software and the Roku player will then restart.
You can comment your serial number or the error message that you're getting. If your getting 011, just power cycle your entire network. Also, please make sure that you're not connecting the Roku to a Guest network. The speed of your connection matters as well. It should be atleast 1.5mbps.
Linksys... | Answered 22 hours ago
DO NOT MAKE THIS SITE WITH YOUR GARBAGE
Take your GARBAGE to another Side
Your message qualifies as SPAM
Linksys... | Answered 2 days ago
****WARNING**** THIS POST IS SPAM AND ALL THAT LOOK LIKE IT ARE SPAM ALSO..NEVER CALL ANY PHONE NUMBERS IN A FIXYA POST. YOUR MONEY AND CREDIT INFORMATION IS IN DANGER IF YOU DO...SO DONT OK??? HAVE A NICE DAY.. YOUR FIXYA SPAM HAMMER....:)... not linksys number anyway
Linksys... | Answered on Sep 12, 2019
[[[[[[[****WARNING THIS POST IS SPAM**** any post with any phone number on fixya is spam. never call any of them
Linksys... | Answered on Aug 16, 2019
;;;;;;;;;;****WARNING THIS POST IS SPAM**** any post with any phone number on fixya is spam. never call any of them
,,,,,,,,****WARNING THIS POST IS SPAM**** any post with any phone number on fixya is spam. never call any of them
Power-off & power-on the router, to reset it.
Otherwise, the router is capable of 1 Gigabit (1000 Megabit) throughput, so it should _not_ be the "bottleneck" (unless you are paying your Internet Service Provider for speeds faster than that!!!)
Linksys... | Answered on Jul 29, 2019
In this Globalisation, using router has become an important need of the users. It becomes an important asset for running the business and even for the household purpose. Linksys is the better networking device for the users according to the current demand. With the help of it, users may expect the prompt service with any major interruption. It is the fact that it has been according to the preference of the users but there are certain issues for which the individual may expect instant help. For getting help at the time of urgency, users could contact the support team.
Several issues are there for which the individual may expect help but here one could see the solution for one:
What is the method to upgrade Linksys router firmware?
•First users need to get the wireless router model number and version number
•Users need to download the latest Linksys router firmware
•It is now required to take the backup of Linksys wireless configuration
•Individuals now need to upgrade the latest Linksys router firmware
•From there users should look that whether the problem get solve or not
For any kind of technical help during the process contact, Router Technical Support team to get an instant solution. They are available 24/7. Call Now ?+1 888 597 3962 for any Support.
More Info - https://www.quickhelps.co/phone-number/linksys/
Linksys... | Answered on Jul 22, 2019
Which Linksys router do you have? Model number.
What error message do you get?
try to connect the computer to the router with the ethernet cable and login to Linksys router setup page. Check the internet connection settings.
Linksys router login
Linksys... | Answered on Jul 08, 2019
What is blocked?
Please explain in detail.
If your router is not working then I will suggest you to reset the router and reconfigure the router.
create a new wireless network and see if that works.
See How to setup Linksys router without CD.
Watch video:
How to reset Linksys router
Linksys... | Answered on Jul 06, 2019
Here is a link to linksys WPA Setup page everything you should need will be there.
Click Here>>> https://www.linksys.com/ca/support-article?articleNum=139152
Linksys... | Answered on May 01, 2019
First and foremost, did you start with the Holy Grail of steps when dealing with routers?
30-30-30
YES! It does make a difference and it matters.
Hopefully you haven't bricked it (probably not).
If it is powered on, press and HOLD the reset button until the VERY END, DO NOT LET UP.
Holding the reset button for 30 seconds, then unplug the power and wait 30 seconds, plug power back in and wait 30 seconds. . . NOW you can let up on the reset button.
Now you can try and reflash the firmware, DO make sure you are using the correct version of DD-WRT for your EXACT model AND Version.
I have only done a few, but the 30/30/30 is crucial I am telling you!
Linksys... | Answered on Mar 04, 2019
Linksys BEFW11S4 v4 broadband DSL router modem switch Logo
1 questions posted
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Linksys Computers & Internet
Most Popular Question
put password linksys befw11s4
  • Computers & Internet
