Side by side frig has drip pan beneath freezer that cannot be pulled out from front but seems to be full. How do I remove it please?
SOURCE: refrigerator water drip pan
thanks for the question no other way to do itthere is no drain hose attached to that tray sorry thanks for the question The appliance doc
SOURCE: how to empty drip pan
At the back of the food compartment where the water collects ,there is a drainage hole, this is blocked up,poke a long thin piece of wire or similar and poke it down the hole, this should clear the blockage,
If the water does not drain away then you need to go the rear of the frig and clear the rubber or plastic hose that you will see on the top of the motor compressor. this should solve the problem.
Plz rate this solution.
Thanks. and merry xmas.
SOURCE: drip pan overflow
you could need more freon, because it is causing the pipes to warm up a bit more then they should be, then the condensation builds up. If the problem still percists after you have this checked, i would put a drain hose on it temporairly and aim for a new fridge if it is from before 1994.
SOURCE: I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
SOURCE: condensation dripping from top of refrigerator
The problem is the defrost drain trough is plugged with ice. You will have to turn off the refrigerator, remove the freezer back panel and use a baby aspirator to help you apply and remove hot water to melt the ice. Then insert the aspirator in the drain hole to blow out any thing that may have gotten lodged inside. You will hear the water draining now to the pain underneath the refrigerator. Hope that helps you, good luck!!
Unplug the refrigerator from the power source and remove the decorative vent cover at the bottom of the fridge under the door. Some vent covers are screwed on but many just snap onto clip that hold them in place.
Pull gently on the exposed front edge of the drip pan and ease it out towards you. The drip pan slides on runners on each side of the bottom of the refrigerator. It may be full of liquid or debris so go slow and steady and then discard it.
we have a kenmore side by side and also cannot remove the drip pan, can you help?
Same problem. It obviously can't be removed from the back. I could only remove it from the front by first removing the filter cartridge holder, a hassle. There must be an easier way to remove the pan for cleaning.
can not get drip pan out to clean
no differant, cant get the pan out.....
yep same prob. HELP
@#$! drip pan. This is a design flaw in one of the highest rated refrigerators. I can only see to remove the water filter cartridge housing in order to get to it. Pain in the a$$. Mold smell getting to me....must keep going....
yes problem getting drip pan out and it is now very gross and moldy as water is not filling up pan but dripping on floor. looked underneath and tryed to see if hose was out of place but looks like hose is hooke directly to pan. Is it possible that hose is plugged and the water is leaking out somewhere else? Model # is 52582201
Our refrigerator drip pan seems to be taped in the front and the back. But, it won't come out for cleaning. SOS. Our model number is 106.44252401.
My Kenmore frige is full of water and spilling! I can't get it out what do I do?
I cant remove the drip pan from my kenmore refrigerator"
