SOURCE: MFC 210C Ink Problems
Steve,
did you watch the display after replacing the cart?
Very often the machine asks if you have changed the cart and demands an answer (1 for yes).
You can try to do an update of the firmware, too. Go to www.brother.com , choose your country and then your machine. Download a small update tool and run it.
If it aint getting better:
Do unplug from power outlet (even though you have done already) wait 10 Min. leave scanner cover open and take all carts out. Plugin to power again and leave scanner open. Wait uintil machine gives a warning signal. Reinsert carts and close cover: now watch the display and give always the answer YES(1).
SOURCE: Brother MFC-210C All-In-One InkJet Printer ERROR 4F
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds.
This should put you in the maintenance mode menu.
Enter 80, then scroll down with the arrow down (round) key.
You'll find an entry listed as purge count.
If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then restart you printer.
SOURCE: i cannot install brother mfc 210c in windows 7
Go to www.brother.com drill down in the support/driver/downloads section. Look for/download avail. drivers for Windows 7 for that device (when Win7 is publicly avail.)
gurutim
