Question about Sony Playstation 3 (PS3) Console
I am trying to use a USB stick in safe mode to update the system software on my ps3 to 3.50. im doing it this way because it will not update via internet without stopping and encountering error 80710723. i have tried turning off media etc etc. anyway when i have the USB plugged in the system says "No Applicable Data Found". why is this, i have tried 3 different USB sticks, all with nothing on them but the update i downloaded from the sony website. so why cant it read the info off of them? i am using a mac, does this effect it?
    Problem Solver:
  • 16 Answers
The fact you're using a Macintosh system should have absolutely no bearing on your memory stick displaying the data for your PS3 to see. What may be the cause, though not very likely, is the format of the memory stick itself. You must first make sure you didn't accidentally change the format from FAT32 while saving the update to the storage. Another possibility is that memory stick may not have been formatted as FAT32 to begin with, which isn't very likely.
Check this first before continuing on. Once this part is settled, or if there are no changes necessary, proceed to the next section.
The next thing you must do is properly and immediately back up your game and save data before applying the update just in case something goes wrong. Once you've completed this part DO NOT enter safe mode again, instead, allow your PS3 to start normally and load all settings and data before proceeding to the next step.
From this point go to Settings > System Update > Update via Storage Media. Press X on the next screen when the system "sees" the data, accept the User Agreement, then start the system update.
Posted on Oct 16, 2010
My Pfaff Creative 4.5 sewing machine is frozen in update mode
Contact manufacturer help desk, and they should be able to sort the issue
Mar 03, 2018 | Cell Phones
When I turn on my playstation 3 it says that it is restoring and then goes to a black screen, any ideas
I think that you may have a problem with either the system files or the HDD. Here are some steps to try before sending the PS3 Back in
First try:
1. Access safe mode with instructions from this link Safe Mode on PS3
2. From safe mode, click restore default settings.
3. If this doesn't work, go back to safe mode and click restore filesystem. If this doesn't work, go back and click the next option down. Stop at restore.
Second: (You will need some supplies)
1. Follow this until you get to the bold letters saying "Update Procedure"
PlayStation3 PC System Software Update Method PlayStation
2. Go back into safe mode and click "System Update"
3. Plug in your USB stick
IF ALL ELSE FAILS:
You need to replace the hard drive. Here are sony's official instructions:
Upgrade the Hard Disk Drive HDD
Make sure you use a PS3 compatible hard drive! (Listed in the above article)
Sep 21, 2014 | Sony PlayStation® 3 (80GB) Console
Ps3 error 8002fb27
this particular error is caused by corrupted data easiest way around this will be to install the update via a usb flash stick.
you can download the update here http://uk.playstation.com/ps3/support/system-software/detail/item541668/Update-features-%28ver-4-31%29/
this link will explain how to update via a Usb stick http://www.ps3news.com/forums/ps3-guides-tutorials/how-install-ps3-firmware-memory-stick-99095.html
Please only use the first to download the firmware only ever trust official sources.
Dec 04, 2012 | Sony Playstation 3 (PS3) Console
Have red screen
1) Follow this link and download the latest FW update (3.15):
http://uk.playstation.com/ps3/support/system-software/detail/item249463/Update-features-%28ver-3-15%29/
2)Transfer the update on to a USB flash drive/pen to connect to the PS3. Stick it in.
3) Access the PS3 Recovery/Safe Mode. This will help to do so:
http://us.playstation.com/support/answer/index.htm?a_id=1488
4) Choose Option 6 - System Update. Should locate the FW file on the USB pen.
Aug 23, 2011 | Sony Playstation 3 (PS3) Console
I reset my ps3 and after that i have to plug the controller to the console whit the usb cable and pres the ps botton and nothing happens
Put your PS3 into safe mode.
Put you finger on the on/off sensor an leave it there until your system turns off take your finger off the on/off sensor and then place it back on leave your finger their until you hear 2 consecutive beeps the remove your finger. This will put you into the system safe mode.
If you you have already done a system restore then start at try rebuilding the database, your system will restart after you do each of the safe mode options. You can also try downloading the 3.56 system software onto a usb via PC and doing a system update in safe mode.
Feb 09, 2011 | Sony Playstation 3 (PS3) Console
I try to download the new version of the system software 3.56 but i only get to 72% of it and it tells me error occured and gives me the number 8002f997
Try accessing the recovery menu 'safe mode'.
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options.You need 6.
You will need to have the latest firmware on a usb stick. Download the firmware from the playstation official website onto a usb stick. Once prompted by your system you will need to insert the usb stick into the PS3. Good luck..
If this doesn't work:
Your HARD DRIVE (aka: Hard Disk), located on the left side of the unit, has crashed. You will need to replace the HD.
When you replace your hard drive, you will need to have the latest firmware on a
PS3. Good luck..
You will need 2.5" Sata Hard Drive.
Jan 28, 2011 | Sony Playstation 3 (PS3) Console
On my PS3 when I try to update it, its keeps on saying error code 8002F994 and that the data is corrupted. Im tying to updated it to 3.5
Your HARD DRIVE (aka: Hard Disk), located on the left side of the unit, may have crashed. You will need to replace the HD.
PS3. Good luck..
Before you replace the hard drive, try:
the middle of your controller. There will be a menu with 6 options. Update using option 6.
PS3. Good luck..
I bought call of duty world at war and then i got the latest map pack when i hit download the ps3 totally froze so i tried and tried again but it just didnt work so not having much on my ps3 anyway i...
Try updating your system the manual way:
the middle of your controller. There will be a menu with 6 options. Perform 6, "system update."
If this doesn't work, when your system froze and you powered it down, you may have corrupted your Hard Drive (Hard Disk). You will need to replace it.
PS3. Good luck..
Jan 26, 2011 | Sony Playstation 3 (PS3) Console
Logitech 880 remote is in safe mode and says A.
Sometimes you want to put the remote in safe mode to recover from the LCD "blue screen of death" or other unsavory events. Usually you do this just before you update the remote's firmware (not software). So, you can try connecting to your computer via USB and, using the Logitech Software, go to Downloads-->Firmware. If you can get through the firmware update, you will probably be ok. Good luck
Oct 19, 2009 | Logitech Harmony 880 LCD Remote Control
Sony Playstation 3 (PS3) Console Logo
152 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
