SOURCE: printer door open message
Apparently a solution has already been posted here: http://www.fixya.com/support/t345435-ip4300canon_printer
The author provides instructions on opening the printer and gluing the sensor into the "open" position (assuming that the sensor still works).
Further to this, the sensors can give way. Try soldering or pushing the two connections together. If you need to test, you will have to put the lid back on but you can leave the sensor out of the rinter by draping between the cover and the frame of the putput tray (be careful not to pinch it. AAMOF I leave my sensor out as even though I've pinched it together it has a habit of coming undone.
SOURCE: Canon PIXMA iP5300 InkJet thinks paper output tray is closed (it isnt) and won't print!
It was rather easy to figure out how to pop the silver plastic outter casing off, but now that I have it off I still can't seem to identify where the switch that signals the paper outter tray is.
SOURCE: Paper output tray is open but message says it is closed
I solved this problem by putting a shim between the door & switch lever.
The shim is just a piece of cardboard/plastic/whatever about the thickness of a credit card & about 1/4 inch wide.
At the lower right corner of the paper outlet is an opening about 1/4 inch square. On the right side deep in this opening is a lever (rather hard to see). When the door is opened it lifts the lever up (presumably telling the printer the door is open). I took a small screwdriver, inserted it into the left side of the opening, turned it counterclockwise until it caught the edge of the lever & lifted it up, inserted the shim below the lever, & withdrew the screwdriver. This solved the problem (it has only recurred once since the shim was put in).
If the shim falls out just reinsert it. Of course, if you ever want to close the door you need to remove the shim first.
SOURCE: cannot download free canon pixma iP1980
http://support-sg.canon-asia.com/P/search?model=PIXMA+iP1980&filter=0&menu=download
here u can download...
