Can you please elaborate? What disc are you talking about, the make/model of your tv and any additional info that can help me suggest you a proper solution.
Sai.
No you cannot record on a DVD. You can use all kinds of USB devices. If you want to use a memory stick then you should put it in a USB card reader and then plug it into the tv.You just have to connect it and record. You do not have to always format it unless the filesystem is raw. As or ormatting it ,I strongly recommend that you format it on a comouter using FAT32 file system and then use it in your tv as this filesystem will be a lot more reliable . To do this connect the USB drive to a computer. When it shows up as a removable drive, right-click on it and click format. Check the box called quick format and then choose FAT32 from the dropdown list next to filesystem. Once its done just plug into your tv, tune into the program you want to record and just press the record button.
teac model :lcdv3257dvr can i record direct on to a blank DVD ? If not how do i format the memory stick for recording.
