Question about Toshiba DVR620 DVD Recorder/VCR
I have a Toshiba DVR620ku DVD/VCR combo. I have the Format Mode properly set to "Video mode." I put in a new, unformatted DVD-R, and the player should format the DVD, but it doesn't. I click "Setup," but it does not give me the "DVD Menu," so I cannot manually format the disc. Options?
Posted by egg99 on
Richard Scheurer
    New Friend:
My brother had the same problem. Toshiba tech support said the disc was already formatted, so the DVD MENU option would not be available. He went straight to dubbing and recorded to the disc. After recording, the DVD MENU option was then available. He thought the disc was not formatted since it was straight out of the package and he always had to format other new discs. Perhaps your disc was actually already formatted?
Posted on Nov 13, 2011
  • Richard Scheurer Nov 13, 2011
    My brother corrected me that the technician said the DVD was formatted by the machine when it was first inserted. He didn't see any messages that the disc was being formatted, though.
How can I INITIALISE a blank DVD-R ?
Some DVD players do not recognize DVD-R formats. Refer to OM and use DVD+R
Jun 24, 2015 | LG RC389H Multi System DVD Recorder and...
DVR620KU From the HDMI connector, how to get non-pinched vertical HDMI images on the TV monitor and on the DVD. Recorded DVD's have been Finalized
Using a DVD-RW disk, try ALL different recording settings even if they don't seem probable and record a sample. If output is correct with all BUT the HDMI-cable, go through ALL picture format settings on the TV when a HDMI-cable is used. Different discs and HDMI cables don't have anything to do with this. I'm still chewing on this...
Dec 15, 2014 | Toshiba DVR620 DVD Recorder/VCR
I have an Orion FTDV2004A tv/vcr/dvd combo. I was playing a DVD movie. When I paused it, it would not start playing again. Now, every DVD I put in, says "reading" and then "incorrect...
Hello
Just power OFF the set by its main power OFF switch, and switch in ON, while listening very close to its mechanism side and see whether there is any sound of disc spin. If disc do not spin inside the mechanism, due to a faulty sled motor, the fault you descrbes here will occur. If disc spins inside, and still it does not reads the disc, the laser pickup unit is faulty and should be replaced. OK.
Nov 06, 2011 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
I have an Orien FTDV2004A tv/vcr/dvd combo. I was playing a DVD movie. When I paused it, it would not start playing again. Now, every DVD I put in, says "reading" and then "incorrect...
Hello
Just unplug the TV from AC mains wall socket, and replug into after 5 minutes or so. This should reset the set to its factory settings. If it does not help you, just take out the disc inside, and insert an other one. See whether it reads it or not. If not, the set need service. Especially service to its DVD mechanical side. OK.
How do you record dvd to vhs and from vhs to dvd
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
The manual for this recorder is on the right side of the page here: http://www.lg.com/us/tv-audio-video/video/LG-dvd-recorder-RC897T.jsp . See page 48 for the screen captures of setting the recording mode part of the dubbing procedure.
I hope this helps.
Mar 19, 2011 | LG RC897T DVD Recorder/VCR Combo
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
Toshiba DVR620KU error E 25 cannot put VHS onto DVDs
Probably copy protection.
You can remove it with a Grex or similar
device.
Jan 08, 2010 | Toshiba DVR620 DVD Recorder/VCR
DVD Computer Compatibility (Toshiba DVD/VHS Recorder D-VR7KC
are you formatting the dvd in the universally accepted, video mode or the incorrect VR mode?
Nov 23, 2008 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Toshiba MW24FM1 has lines across the top of screen. Doesn't seem to matter whether it is on TV, VCR or DVD mode.
Hi there it sounds like the set needs a new frame ic and capisitors it would need to go to a repair shop as it is beyond your skills all the nest Bob
Dec 23, 2007 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Permanent Disc Protection
Hi, UnFormat Problem 1. Try Panasonic DVD-RAM, format that on the recorder, donot finalize OR 2. Try this http://www.videohelp.com/forum/archive/repair-guide-for-panasonics-dmr-e60-gh-quot-unformat-quot-error-t299504.html There is a jpg image on the above URL for guidance Hope your problem vanishes :) Moulee [email protected]
Aug 03, 2007 | Panasonic DMR-E75V DVD Player/VCR
Toshiba DVR620 DVD Recorder/VCR Logo
Top Toshiba Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
