Dear codger19:
If your camera gives you "card locked" error messages with several cards and you KNOW that the cards are indeed not locked via the sliding lock mechanism, then your camera needs to be sent in for service as it has developed and electrical communications problem within the memory card control function.
I would first however try a hard reset by resetting your camera to the default settings, removing the battery and memory card for two minutes, and then replacing them. Retest the cards for the error message. If it still occurs then call 1-800-828-8080 for your options.
Hope this helps.
Sincerely,
HeavyDLB
Dear codger19,
If the camera is giving you a busy message, remove the card before doing the reset. Extrea long busy messages are often a sign of card damage. After performing the reset, if the card no longer gives you the locked message, format it prior to attempting to use it again.
If it still has a problem at that time then you will probably need to send the unit in for service. Hope that helps ya.
Sincerely,
HeavyDLB
thanks for ya reply but the camera wont let me reset to default settin it keeps saying busy
