Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
Cannon IXUS 40.Saying, Card Locked.How do you unlock it?
Posted by enquiries450 on
Dixit Sardana
  • 813 Answers
In case it uses the SD card, then there is a lock feature in the card. You will need to unlock the card so that it becomes read/write enabled. In lock position, it is read only, so you can read the files from it but cannot create any more files.
Most SD cards have a switch on the edge of one side of the card. Sliding it up or down will unlock or lock the card. When the card is locked, you will not be able to transfer any audio tracks. Nor will you be able to play any copy protected files. We recommend you always keep the card unlocked.
Cannon IXUS 40.Saying, Card Locked. - sd%20card%20lock%20slider.jpgNOTE: We have found that on some cards, if the slider is even halfway towards the lock position, the card will be locked. Make sure that the slider is all the way to the UN-locked position.
Posted on Nov 24, 2009
Card locked on cannon ixus 8105 digital camera
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 03, 2012 | Canon Cameras
MEMORY CARD OF cannon digital IXUS 80 I5 GOT LOCK.HOW TO UNLOCK IT.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 15, 2011 | Canon IXUS 80 IS Digital Camera
My cannon powershot- says the card is locked how do i unlock it?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 07, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
Same problem with the others, the card is locked
If you've already tried the lock/unlock switch on the side of the card, then see this link for additional troubleshooting tips for this problem.
Apr 18, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
I have an issue with my cannon camera. I just came from holidays and took over 500 photos on my ''Canon IXUS 960''. When i connected it to my pc to see all my pictures but i got an error message saying...
you should try some photo recovery software, here are some programs you may rely on. Both programs can also recover videos and music.
Photo Recovery Software (for Windows)
Mac Photo Recovery Software (for Mac OS X)
Note: Before your pictures are recovered, do not attempt to save more files to the camera memory card in case the original files(your pictures) are overwritten.
Mar 14, 2010 | Canon PowerShot SX110 IS Digital Camera
Screen says card locked. How to unlock it?
There will be a small slidable portion on the SD card. By moving it back and forth u can unlock and lock the card
Thank u
Please rate me as it wil cost u just one click
Oct 23, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
How do i unlock my card in my cannon ixus 75 camera
Remove the card and look for a tiny slide switch on the side of the card. Slide it to the other "unlocked" position, and reinsert it in the camera.
Jun 07, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Card locked
Dear codger19:
If your camera gives you "card locked" error messages with several cards and you KNOW that the cards are indeed not locked via the sliding lock mechanism, then your camera needs to be sent in for service as it has developed and electrical communications problem within the memory card control function.
I would first however try a hard reset by resetting your camera to the default settings, removing the battery and memory card for two minutes, and then replacing them. Retest the cards for the error message. If it still occurs then call 1-800-828-8080 for your options.
Hope this helps.
Sincerely,
HeavyDLB
May 31, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Ixus 70
On your memory card there is a little switch on the side click it the oppisite way you have it and it should unlock the memory card
lock and unlock you want to unlock it
Jul 16, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
661 people viewed this question
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
