20 Most Recent Canon PowerShot SD300 / IXUS 40 Digital Camera Questions & Answers
SD cards have a small micro switch on the side check to make sure your's is open/on.
Canon PowerShot... | Answered on Nov 18, 2017
Sounds as if it needs a repair but get a quote first as it may be better to purchase new
Follow the instructions beginning on page 31 of this manual.
Canon PowerShot... | Answered on Feb 15, 2013
I Have the Same Problem. it is very Annoying I find it sometimes Helps To push down on the mode button while moving it a across. I think maybe there is a plastic catch that is worn or something. I am thinking of taking it apart and having a look to see if I can fix it.
Canon PowerShot... | Answered on Nov 11, 2012
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Canon PowerShot... | Answered on Oct 04, 2012
When you play the video back and get no sound are you doing this on your camera or on the computer? I have the same camera, and noticed that when I playback something I've recorded I don't have sound either, mind you I don't have static either. But once I've uploaded the video onto my pc the sound is there.
Canon PowerShot... | Answered on Jan 15, 2012
I have the same camera. It sounds to me that there is a fault with the camera itself and not the battery. You might be better sending Canon an email and asking them. My battery lasts forever so I would think if you already purchased another battery you've eliminated that problem. It might be the contacts inside the camera that are not accepting the full charge. Does the camera battery on screen show that it's full after you've charged it? Maybe trying charging it overnight and then trying it out the next day.
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Canon PowerShot... | Answered on May 21, 2011
Check to see if your 16GB card is an SDHC card. If it is, your camera is not compatible with SDHC. (The SDHC protocol was developed after the SD300 came out in 2004).
Canon PowerShot... | Answered on May 05, 2011
here you can find the manual for your product:
http://files.canon-europe.com/files/soft24168/Manual/IXUS30IXUS40_CUG_EN.pdf
if you go to page 76 of the manual, you'll find detailed instructions how to setup date stampo embedded in picture.
Let me know if this helped you, bye
Canon PowerShot... | Answered on May 04, 2011
Press the FUNC/SET button. Use up/down to select "My Colors" (the palette icon, fifth from the top). Use left/right to select something other than "B/W" for black-and-white then press FUNC/SET.
Canon PowerShot... | Answered on Mar 15, 2011
Call canon and tell them you have a defective unit.
Canon PowerShot... | Answered on Mar 07, 2011
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea.
Canon PowerShot... | Answered on Feb 10, 2011
Hello
Regards
Andrea
Canon PowerShot... | Answered on Jan 16, 2011
If there is a SD card for your camera, you can do that easily by a card reader
Canon PowerShot... | Answered on Jan 04, 2011
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
146 questions posted
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
setting date
  • Cameras
