If you feel the power adapter working fine with the diff unit its not an issue with the adapter,
Now, if the unit is not powering on.just perform this:
Take out the batter, adapter and make the unit stand alone and press and hold the Power button with out any power to the unit(Without battery , adapter) by doing that we can take the static charge which might be causing the issue,
If that does not fix the issue, try reseating the RM if you are comfortable, here is the steps:
Primary memory board removal
Before you begin: Remove the battery and keyboard.
- Push both arms outward simultaneously to release the primary memory
board to the spring tension position.
Caution! When
handling a memory board, use care
to prevent touching the memory chips on the board. Touching the memory chips
could damage or destroy the memory.
- Grasp the primary memory board by the edges and pull gently to remove
it.
- Place the primary memory board in a static dissipative bag.
Primary memory board replacement
- Remove the primary memory board from the static dissipative bag.
- Locate the alignment slot and align it to the empty board receptacle.
- Grasp the primary memory board by the edges and push gently to replace
it.
Caution! When
- Press the primary memory board down to latch the arms.
Steps to remove Keyboard:
eyboard removal
Before you begin: Remove the battery.
- Loosen the captive P1 Phillips-head screw that secures the memory/Mini
PCI cover to the bottom of the notebook.
- Use your finger or a flat-bladed tool to lift the outside edge of the
memory/Mini PCI cover and remove it.
- Remove the two T8-9 mm screws that secure the keyboard to the base
enclosure.
- Turn the notebook right side up and open the display panel fully.
- Slide the four plastic locking tabs toward the bottom edge of the
keyboard to unlock the keyboard from the LED switch cover.
- Use a flat-bladed tool or your finger to lift the top edge of the
keyboard and then place it upside down on the top cover.
- Using minimal force, lift the locking bar to unlock the keyboard ZIF
connector on the system board.
Important! Use care to prevent damaging
the ZIF connector and ribbon cable.
- Remove the keyboard ribbon cable from the ZIF connector and remove the
keyboard.
Keyboard replacement
- After ensuring that the locking bar on the keyboard ZIF connector is
unlocked, place the keyboard right side up on the top cover.
- Insert the keyboard ribbon cable into the keyboard ZIF connector on the
system board.
the keyboard ribbon cable.
- Push the locking bar down to lock the keyboard ZIF connector on the
system board.
- Toe the tabs on the bottom edge of the keyboard into the top cover.
- Press the keyboard flat and slide the four plastic locking tabs toward
the rear of the notebook to lock the keyboard to the LED switch cover.
- Close the display panel and turn the notebook upside down.
- Replace the two T8-9 mm screws that secure the keyboard to the base
enclosure.
- Toe the memory/Mini PCI cover into the enclosure.
- Tighten the captive P1 Phillips-head screw.
Bummer! any idea about the blank cd rom, I guy here can't see it on Lenove laptop, but we can see it on a HP laptop
