The keyboard connector come in two types.
A plastic connector and usually has a plastic tab that you pull to lift the connector off, DO NOT PULL on the ribbon cable.
The other type is, a ribbon cable that is inserted into a plastic socket on the motherboard. To release the ribbon cable, lift up the plastic catch on both ends of the to release the ribbon cable. When you want to insert the ribbon cable, make sure the catch is in the up position before you insert the ribbon cable, then insert the ribbon cable and the push the ends of the plastic catch down to lock in the ribbon cable.
I may be mistaken, but it may not be 'clipped' to the mainboard such as IDE-drives are to the motherboard,
but the connecton is more of a card nature, so that you should be able to 'carefully!' seperate
keyboard and mb by pulling out the semi-transparent 'cables' . If you're not 100 percent sure, look for repair videos in youtube!
hope this helps
