The chassis of the receiver normally is connected to its ground, it should work, but if want to look for the missing cable please follow the color sequence at the rear connector, the ground wire is the third starting from the yellow cable, the second should be the red one, for more details about your receiver please check the user manual at: http://a248.e.akamai.net/pix.crutchfield.com/Manuals/130/130DEH1700.PDF
Pioneer DEH-1500 CD Receiver Wiring Color Code:
Yellow To terminal always supplied with power regardless of ignition switch position
Red To electric terminal controlled by ignition switch (12 V DC) ON/OFF
Blue/white To system control terminal of the power amp or Auto-antenna relay control terminal (max. 300 mA 12 V DC).
Black (ground) To vehicle (metal) body
To speakers: Grey = right front (+) Grey/black = right front (-) White = left front (+) White/black = left front (-) Violet = right rear (+) Violet/black = right rear (-) Green = left rear (+) Green/black = left rear (-)
RCA connections go to external amp: Red = right speaker White = left speaker
This is the basic layout for most all stereos. The ones that have an orange or orange/white, this is the illumination wire.
Good luck.
Download manual from Pioneer website. Yellow is b+, red is acc, black is chassi ground. Green, brown ,gray and white wires are color paired for speakers. Blue wire is amp remote turn on .Hope this helps
The wires that you are looking for on the back of the radio is the yellow, red, and black. The yellow is for constant power, the red is for power only when the key is turned on, and the black is ground. You need all three in order for it to work.
Black ground Red accessory (keyed) Yellow memory constant power,Blue is remote,Orange is for the dimmer,green with black is Left Lear negative.and green is positive,violet black is Right Rear negative and Violet is positive,white is Left Front positive as for white with black is negative,gray black is Right Front negative and gray is positive
Unless someone cut it off there is a black wire with a spade terminal to connect to the car chassis.
Now go to
http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070339_338834008,00.html
Register, and download your manuals.
Problem solved.
