20 Most Recent Pioneer Avh-p4050dvd Avh-p4100dvd Auto Video Bypass Questions & Answers
If you know how it works USB Clip if you turn on the monitor avic-hrz008
Pioneer Car... | Answered Yesterday
Hello David, indicate model of Pioneer DVD, also make and model of the equipment / TV where you are going to connect it, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola David, indica modelo del DVD Pioneer, tambi?n marca y modelo del equipo/TV donde vas a conectarlo, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Pioneer Car... | Answered on Jun 06, 2019
Request the diagram directly from Pioneer.
Pioneer Car... | Answered on May 31, 2019
Look for languages setting(s)in your menu
Pioneer Car... | Answered on May 29, 2019
Hello Crystal, I do not understand your question, what do you want to do with the Pioneer CX4000?
Indicates brand, model and type of equipment that you are commenting on, in order to find the best possible solution
I wait your answer
Hola Crystal, no entiendo tu pregunta, que es lo quieres realizar con el Pioneer CX4000 ?
Indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Pioneer Car... | Answered on May 26, 2019
Hello Crystal, I do not understand your question, what do you want to do?
I wait your answer
Hola Crystal, no entiendo tu pregunta, que es lo quieres realizar?
Espero tu respuesta
You can't directly plug in the Aux cable. The mini-plug for the AVH-285 is on the back of the receiver but it handles both audio and video from a composite source. (Note: this position means that it isn't easily reached when from the passenger compartment.)
You do need the CD-RM10 composite A/V to mini-plug adapter. The mini-plug port is between the video output and the rear/subwoofer outputs on the receiver. See page 35 of the manual for the picture. If your Aux input device has a 3.5 mm audio out (headphone jack), you'll also need a 3.5 mm (F) to RCA (M/M) adapter.
Pioneer has the manual for the AVH-285BT on the product page: https://pioneer-mea.com/en/products/avh-285bt/ . Two current link to the manual is http://pioneer-mea.com/wp-content/uploads/2015/12/AVH-185DVD285BT.compressed.pdf and https://www.pioneer.com.au/wp-content/uploads/2016/10/AVH285BT-Instruction-Manual.pdf .
I hope this helps.
Pioneer Car... | Answered on May 24, 2019
Check out the ground wire , make sure it's attached to bare metal on frame of vehicle.
Pioneer Car... | Answered on May 14, 2019
in that case, go to setting and fine the time and date to set a correct date in your pioneer
Pioneer Avh-p4050dvd Avh-p4100dvd Auto Video Bypass Logo
Popular Tags
2 questions posted
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Car Audio & Video
Most Popular Question
confused plug aux cable avh 285 pioneer
  • Car Audio & Video
