Posted on May 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The hp psc 1600 is getting dark shadowing when we print items we then brighten up the page but it reverts back to dark shadowing again.
Anonymous
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on May 30, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
Helped
2332
Points
32
Clean the rollers with the help of maintanance option in the printer properties. if not solved check the ink service station unit inside the machine is full with waste ink , clean the waste ink pads and refix it. clean all smudged inks from the paper pickup rollers
A
Anonymous
Reinstal the printer - and put all on default setings....
A
Anonymous
Please check the roller maybe there are dirts stick on it and if found then clean it.
Anonymous
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on May 26, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
0
Helped
2960
Points
35
Just a suggestion, but after you have reinstalled the printer and set them to default settings, use the printer's maintenence button if it has one and use it to clean your rollers and do any maintenence routine that is included in the properties of the printer's maintenence. Most printers will have this feature, but if not then you will have to have the printer serviced as mentioned by shotobaje.
Terry
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
Helped
1050
Points
5
Have the printer serviced. There is probably a smudge somewhere on the rollers inside.
Davor Krstevski
Level 2:
  • Expert 86 Answers
Davor Krstevski
Expert
Level 2:
Answers
86
Questions
Helped
30628
Points
196
Why do I get bleed through of print on pages I print out at bottom of page or shadow print on some?
Paper is too thin (use higher "pound" paper).
-or-
Toner is not of good quality (use HP Brand if possible)
-or-
Printer is set to dark or heavy in your page setup (change to normal or even light)
You can also make sure you are using an HP print driver instead of a generic print driver. Go to HP.com and search print driver for you model, download and install (if you don't already have an HP printer driver loaded on your PC).
How do I prevent my HP 1600 LaserJet from leaving a shadow of printing on the page?
Run 30-40 blank pages through it to take the image off the belt.
Go to Word or another WP program, call up a blank page and print it 30-40 times.
I have a hp laserjet 1600. We replaces all the cartridges and now I am getting shadow printing on the page please help what am I to do?
Did you replace cartridges with OEM HP cartridges or remanufactured/ no name cartridges? The failure rate for remanufactured color cartridges is terrible and it is likely that you have a bad cartridge.
With my HP PSC 1315 all-in-one, about every third time, the page scrolls up to be printed but when it comes out it jams on the right side. I have to stop and get the paper out which is ruined and I have...
Well you can start be cleaning the drums and adjusting the paper tray, if the printer is under warranty then get it checked. There was no recall for this printer, doesn't say that on hp website.
In case of any questions kindly revert.
Thanks. If this was helpful, then kindly rate me.
Solution for printer
* Does the same issue persists while printing from all applications?
* Does the unit print the self test page properly? Steps are given below
* Make sure the printer is loaded with unused white paper.
* Press and hold Cancel on the printer control panel.
* Press Start Color Copy .
* Release both buttons. The self-test page prints.
Please get back to me with the above information. I can solve this problem....
:) Dr Tony
Hp 1600 laser, entire page comes out sligtly black
How old is it?
Page getting dark sounds like the drum getting old.
1helpful
HP PSC 2175 Printer reverts to "default printer" on PC re-boot
click on start ---settings----printer and faxes now from here u can make a default printer just right click on the icon of that print which u want to use and set it as a default print. or if u just want to revert back the current one just uncheck the option by right clicking on the icon
2answers
Hp psc 1600 series
try to give test page from the printer.without using your computer to print, that will help you to locate where the problem is. in the printer or in your pc settings. thanks.
3answers
Print quality
Change the PCU cartridge.
k24674
Grand Canyon Tech
Grand Canyon Tech
