20 Most Recent
HP Hewlett Packard LaserJet 1600 Printer Questions & Answers
OPEN HEAT ERROR
This could usually mean 2 things :
1) Your printer is overheating. Power off and let it rest for an hour and then try again.
2) Your motherboard needs replacement.
I have paper stuck in the fusing delivery stage
paper jams are often difficult in all printers. There is usually a panel on the rear of the printer that you can open. This should allow you to get to the jammed paper and simply pullet out piece by piece if necessary. it can be tedious, but, with a little you should be able to free up the unit
Plain black printing is fine but when using
This sounds like a software problem. Please check to see that you have all the right software drivers installed. If so, try reinstalling them from the installation disk as the code may have been corrupted. Also try turning the unit on and off again to reboot!
The magenta won't print even though its a new
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
HP 1600 HOW DO i RESET THE PAGE COUNT
Hi
Your printer is not made for A3 it only for A4 so how are you getting a larger size than an A4 I not understand?
But if you need to print different sizes you need to get an Art or a paint program on your PC that what do, I use Paint Shop Pro to do my scanning on and I can print any size from 1 inch up to an A4.
If you ever think of getting art program of such then makes sure it has tools on it to scan then you can do all sort sizes.
Anyway I have put a PDF manual for your printer on my website for you to look at or download Hope it will be some help for you.
Click Link =
http://www.4all2sell.com/pdf/hp-User-Guide-for-1600-1608-1610-1610v-1610xi-1613.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best
: Pineworks
