20 Most Recent HP PSC 1401 All-In-One Printer Questions & Answers
HP printer drivers/software,
HP PSC 1401... | Answered on Jul 23, 2016
i was also having such kind of problem with my hp printer. I just made a call to hp tech support on toll free- 1-800-585-2494 and talked with technician. they have fixed my problem. hope they will help you as well. HP Customer service
The scanner in my all-in-one HP printer does not scan
HP PSC 1401... | Answered on Jul 01, 2016
error occurred communicating with the scanning device
HP PSC 1401 prints but not scans
Make sure that the unit is not connected to the computer while scaning the alignment page.
Please perform the steps provided in the following HP web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00473766&cc=uk&lc=en&dlc=en&product=1103491
:) Dr Tony
PSC 1401 will print but it will not scan
you'll also need to unplug the printer from the power outlet and keep it like that for about 15 minutes. With the spooler empty, this should clear out the memory of the printer and get you back to a fresh start. This happened a lot with HP 1000 lasers, it's the first time I hear another model having the same issue... but the basic problem is the same, the spooler sends a Get Ready command to the printer, then processes the print document and sends it off. If you erase the document before it's sent to print, or the printer doesnt echo with OK to Print, then the spooler sits and waits for the printer to get ready, and the printer for some reason gets stuck with a Get Ready command without responding back. So clearing the spooler and turning off the printer for 15 seconds usually fixes the problem.
If you liked this explanation please vote with a Thumb Up. Thanks.
HP PSC 1401... | Answered on Apr 20, 2016
Hello, first try reloading the cd that came with it, if that doesn't work then the printer is bad and either needs to be repaired or replace.
HP PSC 1401... | Answered on Nov 21, 2015
Check your Cartridges.
HP PSC 1401... | Answered on Mar 09, 2015
no need of ip address....download driver software in hp website and install...automatically ip will be assigned
HP PSC 1401... | Answered on Aug 20, 2014
Welcome to the ever popular-widely experienced world of:
PAPER SIZE MISMATCH!!!
YES! That wonderful world where unbeknownst to you but knownst to us (OK I watch Spaceballs WAY TOO MUCH) When you are sending a print job, somehow the paper size setting has been changed. Either in the printer itself, or in the print properties settings in your OS.
Double-check those paper size settings and try to print. If it still happens, try resetting the print settings in the printer back to factory default. Make sure you print out the printer configuration before resetting in case you need to reinstall those settings.
HP PSC 1401... | Answered on Nov 06, 2013
sometimes when you change a cartridge it happenes that we touch or somehow dirty the contacts inside the machine, cleaning them with a soft rag and a little spirits should help,
remember to clean the contacts on the cartridge as well
HP PSC 1401... | Answered on Oct 09, 2013
Here are full instructions on how to install the HP Printers onto a windows 7 system
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01890565&tmp_task=setupCategory&lc=en&dlc=en&cc=us&product=1103491
You may need the windows 7 driver for the PSC 1401 printer - listed in the title of your post http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?swlinkmsg=100&lc=en&dlc=en&cc=us&product=1103491 choose the software you have windows 7 32 bit or 64bit
HOWEVER, You mention 1500 - not sure of the exact product but this link list all the HP 1500 products http://h10061.www1.hp.com/ccsearch/search?pname=1500+printer&pid=&productBigSeriesOid=&spid=&opname=&contextual_lname=&pname_desc=&ptype=&stype=&spname=&temp_hql=&product_line_code=&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&qry=driver&Submit.x=0&Submit.y=0&Submit=go choose which on is the EXACT model you have - that will open a list of options - including HOW to install, also links to the drivers
How to tell if you have windows 7 32bit or 64bit
  1. Open System by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clickingSystem and Maintenance, and then clicking System.
  2. Under System, you can view the system type
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
HP PSC 1401... | Answered on Oct 06, 2012
HP PSC 1401 All-In-One Printer Logo
154 questions posted
Clive
Clive
Ekse
Thomas F. Schneider
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
enlarge print size hp 1401
  • Office Equipment & Supplies
