Samsung TXN2771HF 27" TV Logo
Posted on Sep 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get the menu to stay off of the screen on the Samsung TXN2771HF. I know this is an older HD TV but has a great picture.
Anonymous
Level 2:
Habit-Forming:
  • Expert 130 Answers
  • Posted on Sep 28, 2010
Anonymous
Expert
Level 2:
Habit-Forming:
Answers
130
Questions
Helped
23212
Points
385
Hi
is the problem intermitent? if so you might have a defective tack switch in front panel
Samsung LED UA40F6400 suddenly lost picture.
The tcon board or the LCD panel is faulty. You have to replace the TCON board to confim the fault.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Why do my Samsung LED TV turn on with correct sound but don't have picture. The screen stays black. I've already changed my power supply card by a new one?
If TV menu comes on try another source via hdmi could be a source issue with hdcp or copy guard issues. Sound isn't copy guarded but picture is.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Bottom 4 inches of screen blurry on Samsung TXN2771HF. I thought it might be my Direct TV service, but found that problem existed with the DVD player too.
Ther are two focus adjustments on the HV transformer to try.......a technician will center them both then tweek them either way for best over all focus.........your crt(picture tube is probably aging or focus anodes out of range....but we need to try this first
I have a Samsung TXN2771HF 27" TV and the picture has shrunk to an oval shape in the center of the screen.
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=TX-S3082WH Above is your Samsung support site, please go here and download your user manual, so you know all codes etc to service. Then below is a link for a Training repair manual, this will show you how to troubleshoot your issue. The problem, well symptom, is indicative of a failure in the Horizontal Drive circuitry however what exactly has "Caused" it to fail is what must be determined.,
Using the manuals you should work through all troubleshooting steps, ALWAYS start at the Power Supply, and check if the Voltages there are correct, as if they ate NOT, Nothing else can be...
www.scribd.com/.../Samsung-Lcd-Lb350-650-Training-Book
But, trying to repair yourself, is extremely difficult, in any event, so, it is nearly always my professional opinion that one should always get, things attended too by a professional, and obtain a free, "Quote" from the manufacturers recommended service center, Samsung, in your case, please contact a local or head office and ask for a referral to an Authorised service center. I cannot stress how important that last point is. It is even worth the cost of shipping. You see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace.
TV HAS HOURGLASS PICTURE sAMSUNG txn2771HF
Linearity circuit problem. Take service center guidance
No picture on Samsung LNS4051D HD TV.
Maybe the backlight is out, can you see a picture when shining a flashlight on the screen. if yes you have either a bad inverter power supply or bad screen (panel).
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
The convergence is out
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Samsung Model TXN2745FP Flat Screen
Unfortunately not without experience.
Samsung HL-p4674 RB
Sir, Pull up the on screen menu and make sure the unit is set to display 1080i or 720p instead of 480i. This may be the issue. Good Luck
No Picture, No Sound...Please Help
The most common problem this set has is the Horizontal Output shorting, usually caused by the High Voltage transformer drawing to much current. Whether it's the high voltage circuit or the power supply, having a tech look at this set would not be cost effective. Start looking at the newer technology. Hope this helped.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
