20 Most Recent Samsung 5 Series UE32F5000 32" LED TV 1920x1080, 100 Hz, Freeview HD, HDTV Questions & Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Samsung 5 Series... | Answered on Mar 24, 2016
If TV menu comes on try another source via hdmi could be a source issue with hdcp or copy guard issues. Sound isn't copy guarded but picture is.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Samsung 5 Series... | Answered on Mar 23, 2016
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Samsung 5 Series... | Answered on Feb 19, 2015
Ouuuuch.Please explain exact details of what is said.Email me at "skyethespy@att.net"not quotations.I may not be able to answer,but I will try
Samsung 5 Series... | Answered on Mar 09, 2014
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Samsung LE... | Answered on Mar 11, 2015
you will need to replace the leaky capacitors in the power supply circuit. You can locate the faulty capacitors with a visual check. Those that are bulging need to be replaced.
Samsung LE... | Answered on Mar 04, 2015
Most likely the power supply capacitors. you can identify them by their bulging tops.
Samsung LE... | Answered on Jul 24, 2014
Samsung 5 Series UE32F5000 32" LED TV 1920x1080, 100 Hz, Freeview HD, HDTV Logo
4 questions posted
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
View Most Popular
LE Samsung
  • LE Samsung
Most Popular Question
tv fine last night but when turned
  • Televison & Video
