Samsung 40" Model LN-S4051D now has a pink thin pink strip of light going horizontally thru the...
(More)
Samsung 40" Model LN-S4051D now has a pink thin pink strip of light going horizontally thru the middle of the screen.
The manual for my new 40" Samsung LED backlit TV doesn't tell how to assemble or put the TV...
(More)
The manual for my new 40" Samsung LED backlit TV doesn't tell how to assemble or put the TV onto the stand it comes with. Can you help?
my samsung 40 in lnt4061 occasionally has red and teal spots/lines that change according to the...
(More)
my samsung 40 in lnt4061 occasionally has red and teal spots/lines that change according to the shaow and secenery on the picture. Sometimes I will turn it on and the problem will not exist but other times it does. When it originally happened it was only the red color. I left it turned off for nearly a month and when I turned it back on i worked fine for roughly two weeks. Now the regularity as well as the scale of the problme has increased. Somebody HELP!!!!!! Thanks
Our Samsung LCD goes black and loses sound intermittently when watching transmissions. Happens for...
(More)
Our Samsung LCD goes black and loses sound intermittently when watching transmissions. Happens for about 5-8 secs then restores. Does not happen when watching DVD or playing Wii. Is this an antenna problem? In Australia
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
