Contributor
- Posted on Sep 22, 2010
Re: My toshiba a70 turns off after just a few minutes on.
Make sure that you do not have the airflow areas blocked, put the machine on a hard flat surface, its more than likely overheating, if you are using a hard surface then make sure there is no dirt inside the fan area, use a high pressure air system to blow out the areas
