Hello experts
I have a problem at work with my Xerox Work Centre M128 when I try to scan into a specific folder.
The error code is 016- 782
Can anyone help me please?
Thanks
Rika .
Post by tryit:
There is an error in the in the server password or a template setting.
Here is the documentation. Pretty straight forward
Login to the Server was not possible during Scan to Server file transfer.
Initial Action Refer to BSD 16.1.
Power OFF/ON
Procedure Set the login name and password in the destination server.
Set the attributes of the Job Template file correctly.
From a client PC, set the same account as the above as a resource using CW.
Rika :
Hi
Thanks for answering so quickly
But I am no expert and I found your instruction very difficult for me.
Can you add more guide lines with no keywords (like BSD /…)
Did u add any documents to your post? My browser cant display any of that .\
Can I get the documents in links ??
So my problem is this – I need to scan to folder (SMB something???) .
I create a special user for the scanner machine with administrator authorization .
I create a folder on the server with authorization for everyone and the scanner user .
When I press "scan to SMB " on the machine and I fill all the fields that required then I press
start and I get the error code : 016-782
thanks a lot .
Rika
Setting up a scanning template using CentreWare Internet Services (CWIS) will fail if the user login name is a domain user, for example, ADSdomain\testadmin.
SOURCE: RE : Xerox WorkCentre M128 016-782
