20 Most Recent Xerox WorkCentre XD100 All-In-One Laser Printer Questions & Answers
error no.j6 asking how to swallow prablam
Xerox WorkCentre... | Answered on Dec 27, 2018
I have a XD100 Work Center with a L6 error code indication. After press "C" Clear (orange color button), followed by "Auto" (the most left small button) - exposure mode key; and "C" followed by "Auto" again, the copier starts to print and solved problem.
Xerox WorkCentre... | Answered on Jan 08, 2018
This machine need a good overall clean out.
Call in an engineer or do it yourself.
Good Luck.
Xerox WorkCentre... | Answered on Jun 02, 2015
The pick up roller need to either need to be clean or replace. Because of the price to replace the pickup roller it might be worth more to just get another printer.
Xerox WorkCentre... | Answered on Apr 21, 2014
Try printer setting to the requisite tray number
Xerox WorkCentre... | Answered on Oct 20, 2013
That means you need to replace both the ink and drum units. What has happened is on the front of the ink cartridge there is a waste sump that has filled up, and in the process has backed up the waster auger in the drum unit. The noise you hear is the auger bowing and snapping from binding .
Xerox WorkCentre... | Answered on Feb 21, 2013
See this thread, someone with a similar problem to you:
http://www.fixyourownprinter.com/forums/laser/24105
I'll summarize the solution:
The "software" H4 problem is quite common that Xerox has a resolution on its website
Solution: Perform a Fault Reset 14
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
1. Find the pink Clear button on the Control Panel of the WorkCentre.
2. Find the button below the word Auto.
3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto]
NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
5. Press the green [Start] button.
6. Press the pink [Clear] button two times.
7. The WorkCentre should now warm up and come to ready.
8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Xerox WorkCentre... | Answered on Sep 05, 2012
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
173 questions posted
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Xerox Office Equipment & Supplies
Most Popular Question
paper feed from tray display shows
  • Office Equipment & Supplies
