If you can, try your monitor on another PC, neighbough or friend if necessary. If it fails, you've a monitor problem, if it works you've a PC problem. Oh ensure you use the same leads each time.
If its the monitor then its a replacement or repair, if its the PC, it could be just the graphics card needs reseating or replacing. Not too expensive if you're not into CAD or gaming. You could try second hand but make sure its compatible with your motherboard.
The power printed circuit board is failing, not
delivering the proper power to the main board and/or the back lamps. One can
have this board repaired inexpensively by a electronic technician. Email me at [email protected]
and we may be able to get your unit working properly again.
