Look for Bad Capacitors on ther power supply board located on left hand side of chassis Caps will be vented,swollen or puffed up on Top 2200uf 10v 3300uf 10v 1000uf 16v 680uf
Hi
Thanks for using FixYa. As you
have already replaced the lamp so the issue seems to be with the ballast (which
is the power supply source for the lamp) going bad and needs to be replaced. As
the sound is working fine so don’t think anything else is causing this issue. Please do accept the solution if the issue is resolved
or post a comment for further assistance.
Thanks
Rylee
Be advised that the engagement of any device in a Tape Monitor loop on a late-model Audio/Video Receiver will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? The rest would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that
Is there a test point on the lamp where I can measure incoming voltage and confirm ballast failure ?
Can you recommend a parts depot that stocks this ballast ?
Thanks,
Jim
