Samsung HLR5667W 56 in. Rear Projection HDTV Television
Problems with Samsung HLR5667W 56 in. Rear Projection HDTV...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Samsung HLR5667W 56 in. Rear Projection...
Troubleshooting and Support
Solved Problems for Samsung HLR5667W 56 in. Rear Projection HDTV Television RSS Feed
View More Results for Samsung HLR5667W 56 in. Rear Projection HDTV Television
Questions and Unsolved Support Problems
Unsolved Problems for Samsung HLR5667W 56 in. Rear Projection HDTV Television RSS Feed
Answer
Our Samsung DLP 50" TV has green checkerboard type lines running through the screen however,... (More)
Answer
How do i install a BP94-02084A digital board into a Samsung HLR4667W TV?
Answer
the screen is showing green stripes. I have audio and dvds will play but I cant get cable channels... (More)
Answer
I have a 56 inch DLP that is 4 to 5 years old. If i try to use the audio/video ports for a dvd or... (More)
Answer
When using the RF input, all I see is a greenish screen with sort of a checkerboard pattern of bars.... (More)
Answer
the tv will not come on , but was playing the night before . it did come on once , but then went off... (More)
Find a Manual
Samsung HLR5667W 56 in. Rear Projection HDTV Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Samsung HLR5667W 56 in. Rear Projection HDTV...
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Samsung HLR5667W 56 in. Rear Projection HDTV Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Samsung HLR5667W 56 in. Rear Projection HDTV Television
Key Features
Screen Size
56 inch
Display Format
720p (HDTV)
Digital TV Standard
HDTV
Projector Technology
DLP
Display Capabilities
Aspect Ratio
16:9
Built-in Tuner
NTSC · ATSC
Remote Control
Remote Control
Multibrand
Illuminated Remote
Non-Illuminated
Image Quality
Comb Filter
3DYC / 3D Digital
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Type
Virtual Surround
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Secondary Audio Programming (SAP)
With SAP
Technical Features
Picture in Picture
With PIP
Parental Control
V-Chip
Sleep Timer
With Sleep Timer
Connectors
Rear Input Connectors
Component x 2 · S-Video x 2 · DVI x 1 · Audio (RCA) x 5 · Composite x 2 · RF x 2 · HDMI x 1
Rear Output Connectors
Composite x 1 · Audio (RCA) x 1 · RF x 1 · S-Video x 1
Memory Card Slot
PC Card
Screen Text
OSD Languages
English · French · Spanish
Channel Labels
With Channel Labels
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 15 Watt
Dimensions
Depth
15.3 in.
Height
37.9 in.
Width
52.4 in.
Weight
80.9 lb.
Samsung Contact Information
Main support number1-800-SAMSUNG
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
