When I turn on tv,it shows a white screen and don't anything do
Hello
You haven't specified anything about your TVs sound condition. If the sound is there and only the picture is out, leaving a white screen behind, it is due to the R-G-B output section of your TV. The section mentioned above comes on the picture tube base card, a circuit board connected on the neck of the picture tube, directly pluged onto it, with the help of a socket called picture tube base socket. You just measure the voltage to it first. The main voltage comes to it from the secondary voltage winding from the line output transformer, [LOT], generally, or from the SMPS power supply itself. It will come upto 260VDC, and must be there. If this voltage is missing, the fault you mentioned will occur. If this voltage is there, the fault may be due to a decective video output section. It may be built in with transistors, or an integrated circuit [IC].
Usually, Samsung uses Philips IC, number [TDA 6007B], or its equivalent in this stage. Check for any loose, or bad soldering on the terminals of this IC. I advice you to resolder all the pins of this Ic, by applying a little more soder, without making any short circuit bridges in between them. zin most cases, this will solve the problem. If it doesn't help, replace the IC with an identical in type and number.
If you wants anymore asistance, feel free to get me through Fixya. OK.
