Philips 55PP9352 55 in. Television
Problems with Philips 55PP9352 55 in. Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Philips 55PP9352 55 in. Television RSS Feed
Click here to get instant support from our best Experts!
View More Results for Philips 55PP9352 55 in. Television
Questions and Unsolved Support Problems
Unsolved Problems for Philips 55PP9352 55 in. Television RSS Feed
Answer
Our projection tv is losing its color. It has been fuzzy for a while. Will new bulbs fix the... (More)
Answer
Panasonic 55PP935217 CRT Projection Red Gun does not want to align/converge...via the remote - left... (More)
Answer
Just inherited a philips 55PP9352 TV and took it home. we can't get it to hook up to cable. All we... (More)
Answer
the tv worked fine last night but when i went to turn it on this morning it came on show static for... (More)
Answer
where is the AV button on al old Philips tv, don't know the year, model and I don't have a remote... (More)
Answer
The tv is a philips 55pp9352/17 rear projection manufactured in 2002.
Find a Manual
Philips 55PP9352 55 in. Television Manuals & Guides
Tips & Tricks
(Post a New Tip)
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
The Fl231 PROBLEM(CONVERGENCE NOT IN CUSTOMER MENU) ITC22 chasis
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and... written by willtab
Updated! Convergence Problems & Solutions - With example photos
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV... written by Ecollier2012
How To Fix A Convergence Problem
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen... written by Ecollier2012
Distorted Video - Convergence Problems - 3D Looking
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the... written by Ecollier2012
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for 55PP9352 55 in. Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Ratings for the Philips 55PP9352 55 in. Television
Owners Recommend
out of 3
Reliability
Ease of use
Value for Money
Find a Warranty
Specifications for Philips 55PP9352 55 in. Television
Key Features
Screen Size
55 inch
Display Capabilities
Aspect Ratio
16:9 · 4:3 Enhanced
Image Quality
Comb Filter
3DYC / 3D Digital
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Type
Virtual Surround
Technical Features
Picture in Picture
With PIP
Sleep Timer
With Sleep Timer
Energy Star Compliant
Connectors
Headphone Jack
With Headphone Jack
Screen Text
Closed Caption on Mute
With Closed Caption On Mute
Dimensions
Depth
25.6 in.
Height
57 in.
Width
52.6 in.
Weight
198 lb.
Warranty
Overall Warranty
1 Year
Tube Warranty
2 Years
Philips Contact Information
Main support number1-888-PHILIPS
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
