Posted on May 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MFC 465cn only 2 mth old. Faxes come out with striations parallel to the width of the paper
  • Anonymous Mar 19, 2014
    paper comes out all dark with striations
Anonymous
Level 3:
  • Master 832 Answers
  • Posted on May 15, 2008
Anonymous
Master
Level 3:
Answers
832
Questions
0
Helped
558001
Points
2204
Give it back to dealer. its in warranty.
HOW DO I PRINT ENVELOPES ON A BROTHER MFC-465CN PRINTER? SCREEN TELLS ME THERE IS A PAPER JAM WHEN THERE'S ONLY ONE ENVELOPE IN THE TRAY.
my brother mfc 7860 tells me i have a jam when i print envelopes only- there is no jam and will print the next 'page' fine- have to turn it on and off 4-5 times to get it to print one- any ideas anyone???
2helpful
2answers
My brother mfc 465cn keeps saying paper jam. I do
The paper sensor is either stuck or dirty.
Just open it and follow the paper path and you should see where it is.
Otherwise, the sensor may be bad.
5helpful
Unable to print 34
This means there may be a paper or object like a paper clip inside the printer. Have you just had a paper jam?
Open the unit and inspect for paper or an object.
Follow the directions in the manual regarding saving any unprinted faxes, then disconnect power for ten seconds. Plug the unit back in. It should be working. If not, it needs service at a Printer service Center
1helpful
I can not clear the memory MC-465CN on the fax - this is a mulitple function Brother - copies, scans, faxes,photo
If you clear the memory, any faxes stored will be also be erased. This solution assumes that you have the fax storage option "On" to store faxes in memory.
On the control panel:
1) Press <Menu>
2) Use <Up> or <Down> arrow keys until "Fax" appears on the display, press <OK>
3) Use <Up> or <Down> until "Remote Fax Option" or "Advanced Fax Operation" appears, press <OK>
4) Use <Up> or <Down> until "Off" appears, then press <OK>
5) You will be prompted: "Erase all fax?" 1. Yes 2. No
Press <1> to erase all faxes in memory.
6) Press <Stop/Exit> to return to normal function
10helpful
Brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
2helpful
How can I delete the memory on a brother mfc-465cn printer fax machine? It will not receive faxes due to this
Review page 65 in your manual. Changing the "Advanced Fax Operations:"
If received faxes are left in your machine's
memory when you change the Advanced Fax
Operations, the LCD will ask you one of the
following questions:
Erase All Fax?
Yes - Press 1
No - Press 2
Print All Fax?
Yes - Press 1
No - Press 2
• If you press 1, faxes in the memory will
be erased or printed before the setting
changes. If a backup copy has already
been printed it will not be printed again.
• If you press 2, faxes in the memory will
not be erased or printed and the setting
will be unchanged.
8helpful
2answers
It prints in color,but not in black whith a new cartrige.i tryed whith the old one,same result.
I had the same issue and resolved it this way:
- go to Start/Printers and Faxes
- right click the printer
- select Printing Preferences
- choose Inkjet Paper as the Media Type
Mine was set to Plain Paper. I'm not sure if it "magically" changed when I changed the cartridges but setting it to Inkjet Paper did the trick.
I did this after replacing all the cartridges and reinstalling the printer. Try this first and save yourself the money of the cartridges and the hassle of reinstalling.
Same problem Brother MFC 465CN see link below
hello andrew! tell me where the paper is jamming? there must be a peice of paper or something in the machine brother tech
Norman Weimar
Norman Weimar
k24674
