SOURCE: 1080p bush 42 inch tv only displaying 1366x768
1080p refers to the resolution you get when watching television. When you're using the TV as a computer monitor a different resolution scale applies. In other words, television resolution and computer resolution are measured differently.
I
hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
further assistance so that I can help you further.
SOURCE: Bush TV and Setting Default Inputs
Not an expert on this model but generally if you switch the TV on by pressing the remote's power button it will come back using the input you previously used. If you press a channel button it will come back to DTV.
SOURCE: Bush 32" LCD 1080p tv
if the screen flickers in thin lines across horizontaly then it the progressive scan on the HD side, mine does the same so i turn the brightness and sharpness down... problem solved (for me) also mine is ok through scart 1&2, DTV (digi) and ATV (anna)
SOURCE: Connecting a laptop from vga
All you have to do when it comes to connecting your laptop to the TV is get the VGA cable and connect it to the TV from the laptop if it doesnt display automatically try pressing the FN key and F5 simultaneously. this should bring options to determine how the screen displays.
Hope this solution has been helpful?
SOURCE: 32 inch insignia model NS-LCD32f,power problems
Possible that the microprocessor is not working , possible that the fault rotates around the processor, could be the crystal oscillator.
If so the panel or the functions will not work and a confirmed status of the processor must be determined.
