Question about Samsun PN60E550 60" 3D 1080p Plasma TV - 16:9 - HDTV 1080p - 60
Why will my plasma tv not turn on? red light (stand by mode) blinks 5 times then nothing. sometimes takes 5 or 6 or more times to turn off. took off back no visibly blown capacitors
Posted by rblanton2159 on
Electro Med Services
  • Samsun Master
  • 6,694 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Posted on Feb 10, 2016
There is a blinking red light next to power button.Panasonic tv will not turn on.
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the
defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
Hopefully it eventually stops blinking after unplugging set from the outlet, otherwise claim your Nobel Prize for wireless energy transmission.
Oct 17, 2014 | Panasonic Viera TH-50PZ80U Plasma TV
42"doesn't turn on
your power supply board is going out.
Dec 06, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
THE POWER STAND BY LIGHT IS FLASHING RED 4 TIMES
Anything less than 5 blinks is major trouble. More likely vertical IC and circuit failure. Picture has been muted or turned off by TV. If Stand By light was blinking 5 times the Stand By might have came out self-diagnosis function or mode.
Contact Sony Service Tech for service adjustment to fix problem.
Oct 21, 2009 | Sony KDF-E42A10 42 in. LCD Television
Red light blinking
You have a bad main board most likely. You can try unpluging it for 5 minutes.
Sep 03, 2009 | Philips 42PF9631D 42 in. Plasma Television
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
No Video or Sound - Red Stand By Light Blinks 6 Times
My book that i have with my tv says it is time to have it servicedby adealer sorry thats all it says
Nov 06, 2007 | Sony FD Trinitron KV-32HV600 32" TV
Samsun PN60E550 60" 3D 1080p Plasma TV - 16:9 - HDTV 1080p - 60 Logo
Top Samsun Televison & Video Experts
Marvin
Marvin
Are you a Samsun Televison and Video Expert? Answer questions, earn points and help others
