If the bottom looks loose then this is usually a problem with top threading so rethread the machine and check that the thread has gone through the tension discs. Lower the pressure foot and pull gently on the thread just before the needle and feel if it is under tension. Is the top tension device set to the middle number setting? usually 5? Unthread the top path, turn the dial to 0 and run the edge of a piece of fabric through the tension discs to clean them. Thread shreds particles of dye and fine thread pieces as you sew so this area needs cleaning regularly.
Also a good idea to check the bobbin thread is under tension correctly and that the bobbin is in the correct way. On my Janome the bobbin thread winds off so that the bobbin turns in an anti-clockwise direction. Mine has a clear bobbin cover with a threading image to remind me of this but check yours and the manual if you have it. Janome bobbins are same top and bottom, usually clear plastic so it is easy to get it wrong sometimes.
Check out
www.sewing.about.com for some good general advice on sewing machine threading and maintenance, it pays to always clean and maintain your machine regularly, use good quality threads and change your needle for EVERY project, don't try and reuse them.
Of course, if you know all this and have tried it already, then perhaps the top tension device has actually failed, if turning the dial up higher makes no differerence at all, then could be mechanic time.
oops, this is for a sewing machine, elna 2006
