20 Most Recent Singer Inspiration 4210 Mechanical Sewing Machine Questions & Answers
Creo que tiene que soltar el tornillo y darle media vuelta para ponerlo al lado. Tambien asegurese que esta bien ensaltado todo el recorrido del hilo. Tambien puede ser la tension, pruebe de poner mas o menos tension.
Singer... | Answered on Nov 21, 2017
Are you looking at your instruction manual? If, you cannot find it, go to www.singerco.com, support and download a free one. I don't see how it won't move to the right if you have it inserted correctly and feeding the right way, look at your book.
Singer... | Answered on Oct 12, 2017
Hi you will have to go through your timing and needle bar adjustment's also could have damaged your check spring on the tension unit
Singer... | Answered on Sep 23, 2017
My nob moves back and forths with the aid of my hand
Singer... | Answered on Sep 27, 2016
you could check with any local sewing repair center .
Singer... | Answered on Aug 15, 2016
the machine may need oiling, check in your sewing machine manual to see about oiling it, it's also possible that the machine could have a damaged or broken part inside,,
Singer... | Answered on Mar 17, 2016
Your top threading is not right, check to make sure that your thread hasn't jumped out of a guide. Totally rethead with the presser foot up, now pull thread, it should move smoothly, next put the presser foot down, the thread should barely move. This will seat your thread in the tension discs. If, that does not work, insert a new needle.
Singer... | Answered on Feb 10, 2016
it sounds like you need a new bobbin case. and it would be a good idea to have the machine serviced
Download the user's manual from the Singer site, www.singerco.com. It is a free download. Look on page 34, and it will show you how to remove the plate and clean underneath. There are two levers that must be set to release it.
From what I gather on other sites, your thread has to be threaded under tension.... You have to make sure you hear a click when your bringing your thread down to the bottom of the "arm". Also, I thought the bobbin case was rather loosely held in its place, I adjusted this by unscrewing the black plate and moving it over just a smidge. The bobbin is supposed to have some wiggle room, but it kept popping up and making the tiny adjustment seems to have done the trick....for now...
I was just looking at page 27 of your manual, and was wondering if one of your pins is broken off and that is why it won't lock in place. Take a look at it and your manual and see if that is the problem. Then call Singer at 1-800-4singer and see if they will send you another one. If, it is the first time you tried to use it, I am sure that they will help you for free. It probably was damaged when you got it.
It is possible that your timing is off so that the machine is only picking up the thread on the one side and not the other. It may need to be adjusted but there are at least 7 different adjustments that it could be. If you are not very familiar with adjusting your machine I would suggest bringing it in to have it professionally timed otherwise the people at the link I attached may be able to help. Depends on your knowledge and confidence level with your machine. Good luck. Sewing Machine Repair Repair Sewing Machines Sewing Machines Repair Fix...
Singer... | Answered on Feb 04, 2015
Download your user's manual free at the Singer Sewing Machine website; it's on page 41 with drawings.
Singer... | Answered on Dec 20, 2014
When is that happening? Are you unable to bring the bobbin thread up at all so that you can begin stitching, or are you skipping stitches?
Singer... | Answered on Dec 12, 2014
The reverse button may have loosened check for looseness and tighten if possible
Singer... | Answered on Nov 01, 2014
Singer Inspiration 4210 Mechanical Sewing Machine Logo
125 questions posted
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Kelley Buchanan
Kelley Buchanan
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Singer Sewing Machines
Most Popular Question
sewing machine stopped working working
  • Sewing Machines
