20 Most Recent Bernina Activa 130 Questions & Answers
Lets start at square-one. Have you checked the plug fuse ? Have you checked that the 2-pin mains plug is firmly inserted into the socket on the back of the machine ?
If yes to the above ... are there any lights on at all ... sewing light, display backlight ?
If it's completely dead, it's most likely the power supply 'L'-print which is a separate module screwed into the back of the machine below the spool holders. Your best bet is to get the machine checked-out by a Bernina service agent.
Bernina Activa... | Answered on Apr 27, 2019
Unfortunately this is a purchase site. The closest I could get would be for an Activa 220 230 240 . You can download the manual.
Check the picture on no. 7 and see if this isn't your machine.
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Bernina.htm
Hope this helps. Luck!
Bernina Activa... | Answered on Dec 26, 2018
Unfortunately this could be a number of reasons, ranging from simple to hard. Taking the simple first - make sure the 2-pin plug is properly inserted into the machine - if it stops, try wiggling the plug first to see if that 'resets' the machine. If it's OK, it might be the switch on the power supply - I've had a couple that needed replacing, but in all honesty, the problem is probably internal and could range from a poorly-inserted plug on the main control board, to a component problem on the board itself, which could be costly to replace. Is your machine still in warranty (2 years on electronic parts) - if-so, get it checked-out by your Bernina service agent, just in case ... dont go messing-about with the machine yourself. Before doing this ... check exactly what happens when it stops sewing ..... I assume that the foot controller doesn't make any difference ..... check if the sewing light is still on, or the display backlight, and is the display still showing any information, or has it gone blank ? Does it happen on all patterns - straight/zig-zag etc. or a memory pattern ? This may help to identify the likely cause.
Bernina Activa... | Answered on Jul 29, 2018
Do you mean Bernina Activa 130?
- ussualy you have to change just cables 000659.71.13 CABLE CPL. 5-POL or 000659.71.12 CABLE CPL. 5-POL
- order nr. for circuit board is 408832.70.00 L-PRINT CLASSIC UNIVERSAL
- see internet for "where can I purchase ..."
Bernina Activa... | Answered on Feb 21, 2018
Turn your on/off switch to off, unplug from the machine, wait 30 seconds and plug cord back into machine, then into socket. Turn your on button on. See if this will reset it. Be sure to turn any lights off when in the off position.
Bernina Activa... | Answered on Feb 07, 2018
Have you removed the bobbin and inspected the area? Quite possibly there is thread or lint that is preventing movement in that area.
Bernina Activa... | Answered on Jul 17, 2017
If the thread is bunching under the fabric, most likely it is bird nesting.
Bernina artista 180 bottom stitch bunching
The other possibility is that there is an incompatibility of needle/thread/fabric. Be sure to use a brand new needle! Use only good quality sewing machine thread--AVOID old or bargain bin threads!
All About Needles
Bernina Activa... | Answered on May 25, 2017
You have two problems:
1) Sometime it sews fine, but other times it will sew like there is no tension on the thread and create a "birdsnest" in the bobbin compartment.
Cause : Threading the upper thread
- clean upper thread tensions discs
- do not forget "• raise the needle and presser foot" (see manual page 18)
2) Sometimes it just randomly changes ...
Please open new ticket. Give tu us more info. It seems like Short circuit on S-print, but your description is chaotic (not usable)
Bernina Activa... | Answered on Apr 27, 2017
Perhaps the manual would be helpful:
BERNINA activa 210 Support BERNINA
You may want to download and keep this manual. A lot of manuals for older Berninas are no longer available.
Bernina Activa... | Answered on Jan 30, 2017
Remove the needle plate (by pushing on right rear corner of plate) and clean out any lint build up from the feed dogs and replace plate.
Bernina Activa... | Answered on Nov 17, 2016
Is it the bobbin tension that is very loose? Try tightening it. Also check that the bobbin has been installed in the bobbin case, turning the correct direction and that the bobbin tension is threaded properly.
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
If it is the upper tension that is loose and creating "thread nests" under the fabric, the machine is either misthreaded or possibly the thread is not seated completely in the tension disk.
Remove the upper thread from the machine.
ALWAYS RAISE the presser foot and rethread the upper thread from the beginning--verify the thread path is correct.
Set the upper tension to the midway point between high & low number (the factory standard--although it may need tweaking later for your particular machine).
Retest your machine. Hopefully, the issue has been resolved. If not, it may need service.
Tutorials Urban Threads Unique and Awesome Embroidery Designs
What causes Bird Nests Superior Threads
Sewing Machine Thread Bunching Up Here Why
Bernina Activa... | Answered on Oct 03, 2016
The pressure foot is only made to push down on the material, not the feed dogs. If you put it too low it will destroy the feed dogs and the pressure foot as well as the material.
1. To adjust, lower the pressure of the pressure foot as much as you can.
2. Place a thick piece of material under the foot. Turn the hand wheel until the feed dogs are up.
3. The pressure foot rod has a screw that holds it into place. You will adjust the rod by moving it up and down until there is a small amount of pressure on the material. Tighten the screw and try your machine without a needle to see if the material will move. Now, try other thicknesses of material. The rod may need to be slightly adjusted a small amount to get it "just right".
4. PUT IN NEEDLE AND CHECK FOR ALIGNMENT TO THE HOLE. (DANGER IF NOT ALIGNED).
Bernina Activa... | Answered on Sep 03, 2016
plug it into your charger cable and 110volts, there is only one connector that the charger cable will go into.
Bernina Activa... | Answered on Dec 17, 2015
There is one screw on the bottom of the machine in the center of the handwheel end. Remove this screw fully. Then the cover should come off fairly easily. The top of the cover has two pins that slide up into the housing of the machine. So be careful not to break these while removing the cover. Also, the screw that goes in from the bottom is held tight by a metal washer that rests in a plastic channel on the cover. Be sure not to lose this washer. If you do, you will not be able to reattach the cover.
Bernina Activa... | Answered on Nov 03, 2015
I agree with Tally Girl in using a good quality, preferably clear, light machine oil. Do NOT use 3-in-one or cooking oil as both will become "varnished" over time leading to a gummed up machine. I have been repairing both commercial ad domestic sewing machines for 45 years.
Bernina Activa... | Answered on Jun 05, 2015
The thread does pass over the top of the bobbin case to form a stitch, perfectly normal, whether front or top loading bobbin.
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Bernina Activa... | Answered on May 26, 2015
Is the bobbin thread through the needle eye? If not then it needs to be there. The top thread doesn't pull it.
Bernina Activa... | Answered on May 08, 2015
There isn't an automatic button hole on this machine. You can do it manually. Thread the bobbin thread as usual, but put it through the little hole on the hook in the bobbin case. Set the stitch length between 0 and 1, like a nice satin stich. Set the needle position to the far left and the stitch width to 2. Sew down the left side. Center the needle, set the width to 4 and lower the feed dogs, stitch about 6 stitches across the bottom. Then reverse the direction, set the needle to the right, stitch width to 2 and go back up the right side. Lower the feed dogs again, set a wide stitch and finish the top.
Another good option is to buy a universal presser foot shank from Bernina and then attach an old cam type buttonhole attachment from Singer. They make beautiful buttonholes and you can even do a keyhole button hole.
Bernina Activa... | Answered on Apr 27, 2015
Sewing Machines Logo
212 questions posted
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Wayne Buss
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bernina Sewing Machines
Most Popular Question
thread bunching knotting under fabric
  • Sewing Machines
