20 Most Recent Britannia SIE9TLS Electric Kitchen Range Questions & Answers
Remove the glass cover it it has one. Usually the cover is held in place by a metal spring bar going across the front.
Britannia... | Answered on Mar 10, 2015
I thought theses were removed from the top after removing screws or clips that attach the unit to surrounding surfaces.
Could be wrong. But they are usually simple enough for the home owner to remove.
Britannia... | Answered on Oct 20, 2013
The pins from the element were very close to the back panel when fitted. This causes the nuetral to go to earth and bypass the thermostat. Bend the pins 90 degrees and the problem is fixed.
Britannia... | Answered on Oct 18, 2009
5 Common Kitchen Exhaust Fan Problems
You don't often realize how important your kitchen exhaust is until it breaks down. It gets rid of smoke, moist air, and food odors. Luckily, these five common problems are easy to fix.
1. Motor If the motor of the kitchen exhaust fan suddenly begins to make an unusual noise, it may be due to the fact that the motor is struggling to keep the fan running. When it gets to this stage, it is likely to be only a matter of time before the motor burns out completely. In this case, replacing the motor is the best option.
If you have retained the instruction manual, keep this on hand during the removal process to help you to identify relevant components. Switch off the power supply and remove the cover of the fan to access its wires. Carefully unhook them before removing the other fasteners that hold the motor to the support and reverse the steps with the new motor. Ensure that the new part is made by the same manufacturer as the fan and is the correct model. Then check the manual to determine whether it outlines any recommendations as to suppliers.
2. Rattle A kitchen exhaust fan that rattles when it is in operation is likely to have loose or defective components that will have to be rectified. After switching off the power supply, check the fasteners holding the cover in place. If they are correctly secured, unscrew them in order to remove the cover and check for any loose parts. Repair or replace any components that you find to be faulty and make sure the screws are properly tightened when you replace them.
3. Power Failure If the exhaust fan fails to work at all when you switch it on, there are a few possible causes. Check whether the appliance has tripped the circuit breaker and switch it back into place if this has occurred. Alternatively, check whether the fuse has blown and replace it if this is the case.
4. Moisture A build-up of condensation in the kitchen exhaust fan can result in moisture dripping from it and causing staining to the surface beneath. Remove the cover after switching off the power and clean the inner surface of the cover. Check whether you can see a build up of moisture.
5. Wiring The location of a kitchen exhaust fan can sometimes cause the wiring to melt. The wires can also become loose or frayed. In this situation, the wires must be replaced. Turn off the power supply and remove the cover by unscrewing the fasteners that hold it in place. Visually check the wires for any sign that something may be amiss. If they appear to be intact and fault-free, use an ohm meter on the wires that relate to the power switch. If the resulting reading is anything but zero, then the switch is faulty and must be replaced.
SPONSORED CONTENT
Forget Your 401k if you Own a Home (Do This)
By LendingTree
Americans could save thousands by taking advantage of this government programComments
Topics: projects for beginners 2 Reasons Not to Install Heat Recovery Ventilation in Older Buildings
How to Eliminate Mice From Your Home's Ductwork
How to Identify Ductwork Problems
Home Ducting Options
Troubleshooting a Furnace Duct: Banging Noises
HVAC Hacks: Energy-Saving Improvements You Can Make Yourself
How to Seal Leaky Duct Joints
Duct Insulation and and Sealing Considerations
Return Air Vent Efficiency and Proper Placement
The best way to improve the efficiency of your return air vents is to check your furnace filter. If the filter is too old, it is probably reducing the efficiency of your return vents, and you should change it. Furnace filters should be changed every six months anyway.
How Do They Work? A return vent sucks in air and delivers it to the heating/air-conditioning system to be treated. The treated air is then forced out of the air vents into the rooms of the house, starting the cycle over again.
Using Proper Vents Another good way to improve the efficiency of your return is to make sure the grills aren't blocking the airflow. Also, keep in mind that the size of the return vent depends upon the size of both the room and your ducts. Some large spaces might require multiple vents, and some small rooms that don't have vents might benefit from having them. In general, you want your HVAC system to have about as much return capacity as supply capacity.
Proper Placement Sometimes vents get blocked by rugs, couches, or the like. Try to avoid doing this to your vents as it will reduce their efficiency. Some systems have two sets of return vents, one up high for warm air and one low to the floor for cool air. The low vents stay closed in the summer and the high vents stay closed in the winter.
Shutting the Vents A popular misconception about vents is that by shutting some you can improve the efficiency of others. By closing vents, however, you raise the pressure in the ducts, causing more harm than good.
Cleaning The last step in ensuring the efficiency of your return vents is to clean them on a regular basis. You can use your vacuum cleaner. Just remove the grilles and vacuum out any dust you can reach with your attachment. This is sufficient most of the time, but every once in a while you should call in professionals for a more thorough cleaning.
Your return air vent plays a vital role in the cooling and heating of your home. You'll breathe a little easier with these efficiency and placement tips!
Britannia... | Answered on Nov 07, 2018
Tip
How to replace oven door roller assembly in Britannia Si-9TF-SS Range
I took a chance and ordered a new roller unit although the supplier advised it would not fit my Britannia cooker S1-9TF-SS. In fact the roller assembly fitted IS the same but the hole in front of the roller assembly (in cooker body) is 2mm too narrow to remove the old unit.
I removed the screw (1) holding the old assy and pushed it back into the oven side.
I then filled the slot in the side of the oven, taking 1mm+ each side until new assy fitted through. I used a stiff wire hook to hold the assy so I could pull it back into place, replaced the screw and I now have a working oven door. Espares part was better than old unit and I will now replace the roller assy on the other side of door. The small oven door does not get much use so still works fine. Job took about 1hour plus and a bit of bad ******
on Feb 24, 2016 | Kitchen Ranges
Britannia SIE9TLS Electric Kitchen Range Logo
19 questions posted
Top Britannia Kitchen Ranges Experts
James Gettemy
Bill Boyd
ch.vijaysagar
Are you a Britannia Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Britannia Kitchen Ranges
Most Popular Question
change faulty interior light
  • Kitchen Ranges
