if you go into the setting section of the menu you can select the USB mode back again, if this fails to solve the problem, take the back of the player off via 4 very small phillips screws and remove the battery for at least 30 seconds then put it back in and it should be good.
Go under menu, settings and click on usb mode..
there should msc mode and thats what you want it to be
I hope that helps
Please rate accordingly
Computerrep
On the e250, from the main menu, select Settings, then there should be a selection for USB Mode. From there, you can select either MTP mode or MSC mode, which I think is what you meant. See if that helps.
