Question about Belkin Powerline F5D4050 Network Adapter
Hi, I'm having issues with my current set up using two belkin powerline HD (1gbs) adapters. Upstairs I have the virgin media modem, which connects to a Belkin router (about 5 years old). The router then has an ethernet output going into a belkin powerline adapter. The xbox is downstairs and picks up the ethernet from the other powerline adapter. Now. Wirelessly - my router appears to be assigning IP addresses automatically without issue. However, I have no end of trouble when connected with the powerlines. The router will not automatically assign the xbox and ip address, and when I choose to enter one manually it is very hit and miss, sometimes working, sometimes not. It seems to be dependant on what I have turned on first. If its not IP addresses its DNS, and vice versa. Often I'll leave the settings the same, come back an hour later and its fine. Do you have any help please? Thanks, James
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 103 Answers
Reset the powerline and Try with a different network ID. Try with a secure and unsecured powerline network to see if it works that way
Posted on Sep 02, 2010
Using belkin gigabit powerline adapter with a wirless router
Try to configure the 2 routers to work with one another when they are next to each other using standard ;an cable. Once working the powerline should work fine. If you try to configure them when they are apart you have 2 things that could be causing problems to take out the powerline to begin with, then when they are working close, move them apart
Nov 05, 2017 | Computers & Internet
I have just bought Belkin Powerline AV starter kit. I have a Belkin N1 Wireless Modem Router connected through a Carrier PoE adapter. I have tried to connect my Sony TV and PS3 through the powerline units...
Try reset the device and start a new configuration.It seems that your networwork have issues between the router and the powerlines.All need to be in the same network as per router configuration.Connect one adapter to your router and plug it into an available electrical outlet. Plug the second adpter into an available wall outlet and connect the other end to any device with an available Ethernet port such as a gaming console, set-top box, or computer.
pd: OS to use the adapters; Windows 2000, XP or Vista.
Feb 24, 2011 | Belkin Powerline F5D4050 Network Adapter
I have 4 Belkin Powerline adapters, two F5D4074 and two F5D4072. On Belkin website they are declared compatible, but I can't manage to transfer the password between the 72 and the 74, with the result that...
There are two standards for powerline: HomePlug 1.0, which has a maximum link speed of 85Mbps and HomePlug AV, which has a maximum link speed of 200Mbps. You can use the two standards within the same building, but they are not compatible with each other.
HomePlug 1.0 - F5D4050, F5D4070. Powerline Turbo (F5D4071, F5D4073)
HomePlug AV - Powerline AV (F5D4072 + F5D4074 + F5D4077 + F5D4081). Powerline AV+ (F5D4075 + F5D4079) + Powerline HD (F5D4076 + F5D4078) and Powerline HD500 (F5D4085)
Also try to rest the adapters and reconfigure them again.
Dec 31, 2010 | Belkin F5D4074 Network Adapter
Hi am having connection issues with my belkin play n600 router can u help me?
i bought this router earlier in the year. after trying to set it up and having problems i called belkin, who told me to call my internet supplier. virgin tried but couldnt help and told me ring belkin again. after trying everything they told me for about an hour and still no joy, i took it back to the shop.
Dec 11, 2010 | Belkin Play N600 HD Wireless Dual Band...
I have a Belkin powerline adapter with three ethernet ports. The adapter that connects to my modem suddenly went dead. The connection to the modem is good and the outlet is working. The red light that is...
Hi i do understand ur issue ....for this you need to update the firmware so follow these steps to update the firmware
Step 1)Go to the link www.belkin.com/support
Step 2) Click on the adaptor picture
Step 3)Enter the model number of the adaptor which you can check on the adaptor itself-starts with "F5d"
Step 4)Enter that number and click on play icon
Step 5)You will get an DOWNLOAD icon and clivk on that and save on the computer
Step 6)Save that in the desktop
Step 7)Connect modem>>router>>computer
Step 8)Open the browser page and type http://192.168.2.1
Step 9)On the router page towards the left under utilities click on firmware update and update the firmware which is on the desktop
NOTE: THE ABOVE STEPS ARE APPLICABLE IF YOU ARE USING ONLY A BELKIN ROUTER
If still you have any issues contact 24/7 belkin technical support
1-800-2235546
Thank you,with regards
Priya
Aug 22, 2010 | Belkin Powerline F5D4050 Network Adapter
Trouble expanding my Belkin Powerline network
F5D4075 uses Homeplug AV standard and F5D4071 used Home plug 1.0 Turbo. Both are not compatible to each other. So if you form a network, you have to form with the same standard.
Secondly, You need just one Powerline adapter on the router and you can have 2 or 3 adapter connected to 1 computer each and all these computers can connect to the 1 adapter on the router. You do not have to use it in pairs
Apr 25, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Cant connect to wireless router
Make sure the wireless adapter is enabled on the elonex laptop and its properly installed.
Connect wirelessly on the elonex one laptop using the same SSID and security key that you used on your main laptop.
Aug 07, 2008 | Belkin (F5D7230-4) Router (587009)
Can see my network but wont connect
Yes you may trying chaing the channel to 11, because i have hear that chaning the channel will resolve this problem
Oct 23, 2007 | Belkin (F5D9230-4) Wireless Router...
Belkin Powerline F5D4050 Network Adapter Logo
325 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
