0) make sure the tv has not been on for a while so that the lamp has time to cool. 30 minutes is probably adequate.
1) unplug tv
2) remove lamp cover
3) remove rear exhaust cover (if your tv has one)
4) carefully and gently remove all visible dust and dirt, especially from the fans. (I used a vaccum with a brush attachment)
5) remove the lamp according to your tv's instructions. Do not touch the bulb itself. Only handle the housing.
6) clean out any more visible dust and dirt where the lamp was
7) re-insert the lamp
8) tape the lamp cover safety switch so that it is always depressed.
9) plug the tv in
10)
Turn the tv on BUT DO NOT LOOK AT THE LAMP. Just verify that the fans
are spinning. If a fan is not working, you should look into replacing it
as the first step.
11) If the fans are spinning, put the rear exhaust cover back on.
12)
You can remove the tape from the lamp cover safety switch if you want,
but I left it on since I think it was causing my tv to randomly
shutdown. My tv has not shut itself down since taping the switch down.
Put the lamp cover back on.
13) Make sure the rear exhaust is not obstructed. I personally try to keep the rear of my tv at least 1 ft away from the wall.
Didn't need it; repositioning the red/white/yellow connections did the trick.
