Question about Samsung Televison & Video
I have a Samsung 42 inch TV several years old(out of warranty). There are hundreds of little white dots all over the screen, do you know if it would be better to have it fixed or buy a new one? Also i
42 inch HLS4266W
    Top Expert:
  • Samsung Master
  • 76,204 Answers
It will be best to buy a new one.
Posted on May 03, 2012
    Habit-Forming:
  • 110 Answers
This is a died pixels problem, that means that there are some pixels on your LCD panel that are died and can no longer illuminate. This type of LCD monitor problems is hard to solve, but you can do a massage with your finger on the white dots, this can probably solve the problem.
Posted on May 07, 2012
6ya staff
SOURCE:
Anonymous
  • 192 Answers
SOURCE: White Dots (Plazma)
The symptom sounds like a common problem we have found with the plasma panels called diffusion. The cure in Samsung usually is a VSCAN alignment. Since its an SPS-4243 the unit should be under warranty and is covered. Call 1-800-SAMSUNG and they will direct you to the nearest service center.
Posted on Mar 04, 2007
Anonymous
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
I unplugged the TV and now the picture is back.I read that the LCD's are vunerable to static build up so unless my daughter is using her TV I unplug it.
I was thinking about getting a large LCD for the family room but I'm not going to until they improve on this technology.
Good luck to everyone!.
Cheers.
Posted on May 08, 2008
Anonymous
  • 59 Answers
SOURCE: WHITE DOTS IN MY SAMSUNG TV HDTV
the white dots our dead pixles im afraid the only way of fixing this is buying a new display, if you contact samsung and let them no they should be able to give you the price of a new display.
Thanks
Posted on Mar 10, 2009
Anonymous
  • 7 Answers
SOURCE: yellowing spots on 52 inch LCD Mitsubishi display
have the store fix it you need a tech that has the right equipment to fix that. Since you say you replaced the lamp I assume you mean a LCD micro projector not an LCD Flat panel. There is a piece of equipment that a tech should have that can be plugged into the TVs circuit board and it can fix the spots with an electric pulse. I have seen in done on micro projectors in the store that i work by our techs. So my advise is have the store fix it before your warranty runs out.
Posted on Mar 24, 2009
Anonymous
  • 10 Answers
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Posted on May 23, 2009
My tv image goes off while watching tv,I do have audio but no image.
LG 42LS5700 - LG.com
www.lg.com > Home > Support > Product Support
LG ElectronicsTV/Audio/Video; TVs; 42LS5700 ... TV Support Landing Page - HDTV/Netcast/webOS 1.0/webOS 2.0 ... Adjusting Picture Settings - webOS 2.0 Video ... quality and convenience of complimentary shipping when buying directly from LG.com. ... Curved TVs · 22 Inch to 29 Inch Class TVs · 32 Inch to 39 Inch Class TVs · 40 Inch ...
Amazon.com: Customer Reviews: LG 42LS5700 42-Inch ...
www.amazon.com/LG-42LS5700-42-Inch.../B006ZH...
Amazon.com, Inc.LG 42LS5700 42-Inch 1080p 120Hz LED-LCD HDTV with Smart TV (2012 Model). byLG. Size: 42-Inch ..... images are nice and crisp when viewing HD content.
Widescreen TV Black Screen - Repair LCD LED PLASMA ...
? 3:41
https://www.youtube.com/watch?v=RbZncfiOXQA
Jul 13, 2011 - Uploaded by FixItUrselfDummy
Fix your tv with black screen blinking light, popping sound noise. ... Watch QueueQueue ... TV Black Screen - Repair LCD LED PLASMA - Problems SONY LG .... I have a 60 inch samsung DPL tv how can I stop the humming or ... What do I do if my tvturns on but its just a black screen so sound no picture?.
Jan 11, 2016 | LG 42LS5700 42 Inch 1080p 120Hz Smart TV...
Samsung DLP HLS4266W
Check the fittings of the color wheel. Refer this site for more details.
May 17, 2013 | Televison & Video
Samsung HLS4266w pop sound
Remove and inspect the lamp to see if it shattered inside?
Oct 24, 2012 | Samsung HLP6163W 61" Rear Projection...
Dim picture on Samsung HLS4266W, wondering if this simply means to replace the bulb?
It sounds like you may need a new lamp. When the lamp stops functioning, you will not have a picture and the lights on the On/Off control (Lower Speaker Bar, Middle of Set) will flash on and off. Search for instructions, it is easy to replace. Once replaced, the picture is as bright as when new.
Nov 28, 2010 | Samsung HL-S4266W 42" HDTV
How do you remove the base from 42 INCH OLEVIA
on my tv (42 inch) there are sixteen screws on the middle set up in four rows of four each. these are about two or three inches long.
take these out and the base comes off.
hope this helps.
Jun 15, 2009 | Olevia LT42HVi 42 in. LCD Television
42 inch screen
Did you measure diagonally from corner to corner? This is usually how all manufacturers quote screen size. Hope this helps
Dec 07, 2008 | Polaroid FLM-4201 42 in. LCD Television
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
444 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
