Upon boot up the volume window pops up the volume level shows 100 and streams down to 0. can be interrupted but it still continues when the monitor button is released.
My HP w2408 monitor. I just fixed this issue about 5 mins ago after getting tierd of whacking the buttons with anything handy. There are 2 slots on the underside of the monitor, in between the black frame and silver outer frame. Stick a flat screw driver and use a motion as if to literally pull the black frame away from the monitor. Use caution and dont stick the screw driver too far in. You will hear it pop. Do the same to the other side. There are multiple tabs arond the frame including one in the bottom center. Keep pulling on the free ends of the frame till all the tabs come off. Now you will see the buttom assembly, disconnect the small white connector from the montior. If you dont care for the buttons, which if you have a w2408 or any such model you will never use (auto detects input and auto adjusts) then just pop the frame back on. If you want to go further remove the 2 screws on the button assembly pull down on the silver frame to remove the button assembly. I did not go further then this but i read somewhere that if you wash the assembly in some liquid it will work again. I am guessing some good acohol from walgreens will do. For me I am just glad the message when away.
Keep fixing and keep sharing! Corporations that sell to the masses will show respect only when the masses unite.
