your convergence settings are moved and they need to be adjusted and if you adjust and still have the problem then its the problem of convergence STK ICS and they need to be replaced.
for adjusting the convergence please click this link this will help you how to adjust the red, blue and green settings in your tv.
Your TV most likely has a convergence failure. You can get parts and instructions from www.tvrepairkits.com
Here are some of the most common symptoms and example photos of a convergence problem
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
Screen looks 3D
TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include.... •Screen looks 3D •Colors don't line up •One or more colors can't be adjusted when using the convergence menu. •Screen is bowed or warped. •TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
CONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
his is a very common failure on Projection TV sets.
Screen looks 3D
Also - Dull video problems...
You can see some example photos and find a solution here... http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
Go into the convergance mode and clear it up ,ther is also three knobs behind the press board one will adjust the overall background
color ,thew others focus.
the easiest way is to turn the color all the way down to zero. Then notice the overall color of the screen, if it doesnt appear as a good black and white picture you will have to adjust the screens. To do that you have to remove the speaker grill cover and the small access panel, then depending on the chassis you will see a small square with 6 dials on it 3 on top and 3 on the bottom it will have screen stamped on it. adjust those 3 untill your screen appears the best black and white picture as possible. Now if your chassis only has 3 dials on the sgaure control box those are focusdont adjust them. . then the 3 CRT boards will have the dials you need adjust those for the best black and white picture. when your satisfied that you have a good black and white picture. then turn your color back up and adjust the tint.Let me know if you need more assistance.
