LG WM2487H Front Load Washer Logo
Anonymous Posted on Jul 02, 2010
Thermistor on wm2487h*m lg washer
Where is the Thermistor on wm2487h*m lg washer located ?
  • Anonymous Aug 24, 2010
    If you tip the washer back you can get at it from the bottom. It is not easy , but easier than taking the washer apart.
Anonymous
Level 2:
New Friend:
  • Expert 185 Answers
  • Posted on Aug 24, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
185
Questions
0
Helped
76393
Points
345
Usually on the front outer drum wall. front of machine will need to be removed.
I have the LG wm2487h*ma front load washer.My washer is filling up with water when not in use. When I wash a load, the water does not go in the washer. Have opened the door thinking the wash cycle is done...
The problem would appear to be the water inlet solenoid valve.
The valve is not operating correctly for some reason allowing water into the machine even when switched off
3helpful
3answers
I have an error code that looks like an upside-down F and an E. The washer stops, beeps and flashes this symbol. Thank you.
Hi
Error Upside F & E means thermistor error. To access the thermistor--
1. Disassemble the Back cover. 2. Unscrew a screw from the Tub. 3. Unplug the white connector from the thermistor. 4. Pull it out by holding the bracket of the thermistor.
Hope this helps... Please post back if you need more information.
Daniel
My clothes were in the washer and when I went down to check there was an error code. LE The clothes were still wet, and appeared to not have gone through the rinse cycle.
The LE is caused by over sudsing OR clothing trapped between the tubs. The LE: hall sensor shorted/destroyed from sudslock or clothes between tub. Correct the issue and party on.
LG errors:
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too, small too large
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interuption of shocktricity
LG service manuals and repair notes.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
2answers
Getting a "te" error code -- a heating issue?
I had the tE or te error (an L with a line through it) error on my LG front loader and my local appliance store sold me the thermistor for $7. I layed the unit on its side and accessed the thermistor through the bottom. It plugs into the bottom of the tank. Blue and white wires. No screws and 1 tie-wrap. (Leave the rubber grommet in - just pull the thermistor rod out.) Works like a champ!
2helpful
My LG WM2487H has water in the detergent cup at the end of the wash. It has happened twice now.
This is normal.
All LG washers use a siphon system to dispense soap, bleach and fabric softner.
Some times water will remain in the cups depending on the cycle used.
3helpful
LG Wash WM2487H*MA- how to turn the tub clean feature on?
I have had this problem since I bought my washer. Some days the tub clean cycle will work....most days it won't. They have replaced the main board twice and it's still broken. I've had nothing but bad luck with LG appliances. Also bought a lemon fridge that took 4 repairman visits to fix. I will not buy another LG anything!!
5helpful
4answers
I have an LG WM2487 washer and I'm having several
Addressing your error code: We had the same problem with our washer and couldn't find anyone locally that wanted to even look at it. Hence, I had to find a solution myself. I stumbled onto a sight that had service manuals (not just owner manuals), and found that error code there. What looks like an upsidedown F is actually a lower case T, so the error code is really "tE". This indicates a Thermistor fault.
The Thermistor is located next to the heating element at the botom-front of the drum housing (you will probably have to lay the washer on its back to access it). It is in a soft rubber grommet that protrudes about a half inch out of the housing, just to the right of the heater.
In the case of our washer, when I pulled the Thermistor out of the grommet I noticed some rust on the metal part. I simply rubbed the rust off with my thumb, inspected it again, unplugged and re-connected the connector a couple of times, and tested the washer again.
Results: We have now been using the washer for a couple of days with zero errors, and this was a tenacious fault that interrupted every load before. We are finally happy again with our very expensive appliance. I sincerely hope that this helps you and anyone else with this problem.
Lg washer won't spin
Does it power on?
Does water come in at the beginning cycle? Do the lights come on?
Your motor has a warranty of 7 years from purchase date. Call 1-800-243-0000 for service.
2answers
Need Service manual and parts manual for: WM2487H*MA
http://www.lge.com/us/appliances/washers/LG-steam-washer-WM2487HRMA.jsp
Click on "Support" and you should be able to download the manual.
2answers
Error code upside fe
But U still haven't told us specifically what the issue is with the device. So how can anyone help you?!?!?!?!?!
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
