See or hear if the fan inside is working. Im not conversant with your model. Some units have 2 fans , 1 in the freezer and 1 in the fridge. Some only have1 , which will be in the freezer only. If the fan fails, the fridge cannot blow cold air into the food compartment. Generally, when an evaporator fan fails, the fridge doesn't get cold and the freezer overfreezes causing an excess ice buildup in the freezer.
there may be a large amount of ice build up on the evaporator coils.you alos need to check and make sure that the evap fan is running in the freezer compartment.if you do not here the fan running when the ridge is in a cooling mode replace it. if there is alot of ice you may need to replace the defrost timer
OK, First let us check the compressor to see if running or trying to start. Pull away from wall and unplug from wall. Remove lower cover and feel the compressor top of the to see if too hot to hold hand there, cool or warm. look inside freezer and tell me if ice is building on rear wall. Answer that and I will be able to tell you what we need to do, Thanks, Sea Breeze
I would guess that the condenser fan isn't running. It's underneath the fridge behind the cardboard cover on the back. It should be running when the compressor runs. You can place your own fan on the floor blowing under the fridge till you get it fixed.
