Toshiba 32HL67 32 in. LCD Television Logo
Posted on Apr 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv problem The picture is too big for the screen thus cutting off the top and bottom (e.g., cannot see sporting event scores and time). Tried everything on the remote to no avail.....help please
Benjamin Patri
Level 3:
  • Master 3,037 Answers
  • Posted on Apr 15, 2008
Benjamin Patri
Master
Level 3:
Answers
3037
Questions
7
Helped
707125
Points
8239
You need to calibrate it by using a calibration disc
You should get the Avia disc
You can find them for sale everywhere online by just searching "Avia disc"
You could probably get one from an electronics store otherwise too.
Please let me know if you need any further help.
Thank you for using Fixya and Good luck
Anonymous
Level 3:
  • Master 1,512 Answers
Anonymous
Master
Level 3:
Answers
1512
Questions
13
Helped
829751
Points
3938
Hi Psybill
you possibly have a power supply problem. It will be running high volts, and blooming the screen as a result. I suggest you get this sorted quickly, as failure is eminent:)
regards
Graeme
  • Anonymous Apr 15, 2008
    Oh... and then I read it is an LCD. Disregard my solution mate, It does sound like the set is in the wrong mode. You will need to go through the onscreen menu to find the aspect settings and correct the problem. If you cannot reset the aspect ratio, then the set does have a fault.
    regards
    Graeme
Anonymous
Level 2:
Scholar:
  • Expert 170 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
170
Questions
0
Helped
76295
Points
356
Look on your remote for and aspect button. if you dont see one then try lookin in your menu on your set to see if you can find this option and adjust it to whatever you need.
Pictureis too big for screen
go to your settings and check tv resolution,tv display and tv ratio
2answers
Screen resolution - Picture too big for screen
the resolution from the source is set too high, also check the settings in your television it may be set too high.
Picture is too big for the screen i/e scores on sporting events cannot be read
Look for a "Zoom" or "Aspect" button on your remote. Press that untill the picture fits your screen properly.
2helpful
LG TV MODEL 442L0520 SERIAL 005RMKUA3341 PICTURE IS TOO BIG FOR THE SCREEN,K TOP AND SIDES CUT OFF. WHEN WATCHING SPORTING EVENTS, SCORES CANNOT BE SEEN.
You need to go into the TV menu and change the settings for the display! Press the Menu button and adjust the Picture! It's probably set to automatic and not reading them correctly.
54helpful
3answers
Part of the picture is being cut off, how do i
Just called Sony about this same problem...taking your CABLE BOX remote, push the # key on the bottom right of the remote (it also says HD Zoom on mine). You can cycle through 4 or 5 zoom options...make sure you are on an HD channel to see the changes. :)
go to page 37 of the manual and read through to RESET TO FACTORY SETTINGS
Thanks for using FIXYA
2answers
Picture too big.
HDTV's come with selections that will change the screens display, on the remote press the format button and you should be able to find a setting that you desire.
2helpful
Picture doesn't fit the screen
Try locating the aspect ratio adjustment on your cable box if you have one.
2helpful
Picture size won't fit screen. Can't see scrolling text at bottom (e.g. sports scores on ESPN)
hi there,
its probably not the tv but the set top box you need to fix. go to the settings and select the mode you want ie. widescreen 16:9 etc
then go to the tv and select the full mode or widescreen mode at 16:9
that should solve your problem. it takes some time to find the combination between the set top box and the tv to get it right
good luck
smeags
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
