Troubleshooting & Support
Hot Topics:
- usb service...
- vizio 42 lcd
- picture
- vizio
- flickering
- turn off itself
- main board
- signal board
- blank
- popping sound
- screen flickers
- vizio tv
- line top screen
- remote
- Vizio 42 LCD TV
- power
- strobe
- turn itself
- usb
- hard reset
- sound
- picture sound
- dark line...
- dark
- buzzing
- green
- dark spot...
- pson
- volume loss
- top
- View All »
Problems & Solutions
can i stop the flickering tv
Depends on several things--does it do it all the time and on ALL inputs?A photo of what it looks like posted on the internet at a photo...
VW46LFHDTV10A Black Screen no sound or menu
It could be several things, but I would lean towards a defective main board. But you also may want to check power supply for correct...
I broke my Vizio 42inch E422VA screen. Can I have...
Yes but the cost to replace it will exceed the cost of a new set. I wish I would have come across your post earlier. I just sold a E422VA...
can the vizio send emails
If it is designed to use and accept wifi it may.Google is a good source of information if you Google the model number for "manual"...
visio remote sensor does not respond
HelloYou may not have set the remot to TV with its set up code. If you have did it, and still there is no response by the TV to remote...
Replacing a Vizio Backlight Inverter
I have a television that did this. The picture went out but it continued to have sound. It was the projector bulb. I...
Vizio LCD dark screen and picture is flickering...
Your back light inverter is provably bad.You can get get parts for this tv at www.interliquidparts.com
have had visio 42 inch
You are having a power issue
Have a three year old Vizio 42 inch that has no
Sometimes there is a service panel on the back of the tv that you can remove with a screwdriver. If there is a fuse, take it out and replace...
tv completeley went out , first the picture then
Hi, On the Vizio LCD TVs there are only two boards: Main board and power board. There is also the screen. If they checked the power board...
cannot turn it on with the Directv remote. What
Hello Codes to check with Vizio TV with [Direct TV RC-64 for WEB Universal remote control] are: 10864, 10885, 11499, 11756, 11758 OK.
I had a nearby lightning strike. Now I get...
Hi Just try with component input, and see whether it works fine. If it works fine with component input, the tuner section in your TV has got...
when tv is turned on video flashes sometimes fo
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both. Any caps in...
my tv is plugged in
You may have power supply module failure, it can be as simple as a blown fuse. You need to open it up, parts can be found at...
i have a vizio 42" lcd tv and it is a 2007...
Good day! if you don't have any bulged top capacitors on the power supply. Please try this procedure on how to fix that problem. ...
Unsolved Problems
can not see everything in my tv guide screen
can not make zoom in picture
no picture
Black screen with blue bar across top. Have Sound.
my vizio tv won't turn off screen black model...
started beeping last night, tuned off with button on tv, turned on this am with remote. screen black,logo lit. Will not...
I cannot turn the closed caption on
I cannot turn my closed caption on. The icon will not even light up. How do I turn it on?
I have a large dark blemish on my vizio lcd that...
Dark blemish on screen that never goes away.
I hooked up a Visio HDTV as my computer monitor...
Works fine with HDMI and with another graphics card. But i need it to be hooked up via VGA in this case. Do i have to...
vizio satellite setup
how do I get satellite setup with remote?
Upload a manual for Vizio 42 in. LCD TV
Specifications
TopProduct MPN
Full Product Name:Vizio 42 in. LCD TV
MPN:VU42LF
Key Features
Weight:48 lb
HDCP Support:With HDCP Support
Image Quality
Output Color:16.77 million colors
Connectors
Front Input Connectors:Composite x 1
Front Input Connectors:Audio (RCA) x 1
Speakers
Number of Speakers:2 Speakers
Speaker Power:2 x 10 Watt
Dimensions
Depth:3.9 in
Height:27.3 in
Width:40.5 in
Warranty
Overall Warranty:1 Year
What's your problem?
Fix-O-Meter
55,721
55,721 people have viewed this product
- 959 people asked about this product.
- 205 people found solutions for this product.
- 117 people have added this product.
Polaroid...
Programming...
Working with...
