Try inserting the disc in your computer. If it reads its fine. Then look if the Slus...... is compatible.maybe thats why it doesn't play. your ps2 must have an old bios system even if slim.
remove the cover, take out the two tiny philips head screws from the cover on the drive and clean the lens with a q-tip dipped in rubbing alcohol. Do this gently! use compressed air to remove the dust collected inside the unit and then reassemble.
Disc Read Error generally means that the game disk cannot be read by your console.
Reasons for Disc Read Error 1. Disk surface scratched or smudged. 2. Disk surface dirty. 3. Lens surface dirty.
Here is what you can try doing.
1. Check the game disc for any scratches or smudges on the surface of the game disc, try to clean them off by using a non-abrasive cotton cloth.
2. If the PS2 console is lying down, please set the console to on its side or if it's on its side set it to flat position, restart the console and then try game again. Always ensure the PlayStation 2 is in a cool, well ventilated place.
3. Remove and reinsert the Memory card of your PS2, restart the console then try running the game again. Other troubleshooting that you can try.
Change the Disc speed of the PS2 DVD and then try again.
Start the PS2 with no disc in a drive. Press the "triangle" button on the controller. Use the up and down buttons on the controller to select "Playstation Driver” and press the "triangle" button on the controller. Select Disc speed. If it is set to "Fast," select "Standard"; if it is set to "Standard", select "Fast" and press the "X" button on the controller. Press the "O" button on the controller. Insert the game disc and restart the PS2. Try running the game again.
Turn the Diagnosis On for PlayStation2 to auto detect the best settings.
From the Browser and System Configuration menu. Press the triangle button to select Version. Highlight the Console from the list and press the triangle button - this accesses the next menu option. The Diagnosis will be highlighted. Press the X button to access the options available. Highlight "ON" and press the X button to affect the change. Restart the console and try the game again.
If the above steps does do not solve the error then you would probably have to replace the disc.
Note: If you are using the Slim version of PS2 make sure that the console is properly ventilated and that it should always be in the standing position, as the slim version of PS2 no fan or any other cooling unit unlike the normal PS2.
You said the model is 77001?? is that the slim type ps2?? if it is try this troubleshooting step
if the console is lying down flat where the disc lid is at the right side, try applying pressure on the lower right corner of the lid, sometimes the lid's safety button gets worn out and it will give you disc read error if this solves the problem then the button really is busted, if you have technical background you try and change the button
After extensive research on this subject and working on several Playstation II systems. I found out the reason your system will play only blue disks and not silver is a alignment problem with the laser. It could be tilted or set to high or low. The quickest solution is to call Sony and get a new laser with the shuttle.
If i am not mistaken it cost 50.00 and just go to the playstation site select support and it will explain in full detail how to take your system apart and replace the laser and shuttle.
